Question on STM32CubeIDE and remote debugging
‎2019-12-05 9:29 PM
I am looking for some guidelines on how to make remote debugging possible with STM32CubeIDE running on Win10x64 and my STM32F070RB board connected to a Linux host.
Everything works fine when the device is connected locally, but there is an option to "connect to remote GDB server" in the IDE and I am not 100% on what should be running on the Linux host.
I installed stlink-server from ST on the linux host and run it with the following:
$ sudo stlink-server --network -p 61234 -d 3
Looks like the device is found:
Debug: 1 0 options.c:113 add_default_dirs(): run_prefix=
Debug: 2 0 main.c:100 main(): create_listening_sockets
Debug: 3 0 common.c:103 create_listening_sockets(): Entering create_listening_sockets()
Debug: 4 0 common.c:104 create_listening_sockets(): Creating the list of sockets to listen for ...
Debug: 5 0 common.c:117 create_listening_sockets(): interface, tcp port : (null) , 61234
Info : 6 0 common.c:118 create_listening_sockets(): default port : 61234
Debug: 7 1 common.c:133 create_listening_sockets(): getaddrinfo successful. Enumerating the returned addresses ...
Debug: 8 1 common.c:138 create_listening_sockets(): Processing Address 0x1f7f370 returned by getaddrinfo(1) : (null)
Debug: 9 1 common.c:154 create_listening_sockets(): Created socket with handle = 3
Info : 10 1 common.c:83 print_address_string(): Remote address: 0.0.0.0
Debug: 11 1 common.c:207 create_listening_sockets(): Socket bound successfully
Debug: 12 1 common.c:219 create_listening_sockets(): Non Blocking Setting
Debug: 13 1 sock_info.c:74 alloc_sock_info(): alloc_init_sock_info : Allocated 0x1f7f410
Debug: 14 1 common.c:237 create_listening_sockets(): Added socket to list of listening sockets
Debug: 15 1 common.c:247 create_listening_sockets(): Freed the memory allocated for res by getaddrinfo
Debug: 16 1 common.c:250 create_listening_sockets(): Exiting create_listening_sockets()
Debug: 17 1 libusb1_common.c:145 stlink_libusb_init(): stlink_libusb_init
Debug: 18 23 libusb1_common.c:154 stlink_libusb_init(): libusb version : 1.0.23.11397 : http://libusb.info
Debug: 19 23 libusb1_common.c:382 stlink_libusb_open(): libusb_get_device_list entry
Debug: 20 24 libusb1_common.c:400 stlink_libusb_open(): libusb_open success 0664FF363732594D43163107
Debug: 21 24 stlink_api.c:112 get_stlink_by_name(): usb not found : 0x23befa52
Debug: 22 25 libusb1_common.c:423 stlink_libusb_open(): add to list vendor_id 0x483, devs 0x374b, 0664FF363732594D43163107
Debug: 23 25 libusb1_common.c:429 stlink_libusb_open(): new_stlink->dev->dev = 0x1f8a480, new_stlink->dev->fd = 0x1f99130
Debug: 24 25 libusb1_common.c:436 stlink_libusb_open(): close new_stlink->dev->dev = 0x1f8a480, new_stlink->dev->fd = 0x1f99130
Debug: 25 25 libusb1_common.c:450 stlink_libusb_open(): close usb device 0x1f8a480, 0x1f99130
However, when I setup IDE with remote debugger and start the debug, I see the following in the stlink-server:
Debug: 33 174755 accept.c:190 non_blocking_accept_main(): listening state : 1
Debug: 34 174755 common.c:290 process_accept_event(): Entering process_accept_event() on socket 3, sock_info 0x1f7f410
Info : 35 174755 common.c:83 print_address_string(): Remote address: 192.168.88.10
Debug: 36 174755 sock_info.c:74 alloc_sock_info(): alloc_init_sock_info : Allocated 0x1f8b860
Debug: 37 174755 common.c:329 process_accept_event(): Added accepted socket 10 to list of sockets
Debug: 38 174756 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received +$qSupported:multiprocess+;swbreak+;hwbreak+;qRelocInsn+;fork-events+;vfork-events+;exec-events+;vContSupported+;QThreadEvents+;no-resumed+#df
Debug: 39 174756 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 40 176771 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received $qSupported:multiprocess+;swbreak+;hwbreak+;qRelocInsn+;fork-events+;vfork-events+;exec-events+;vContSupported+;QThreadEvents+;no-resumed+#df
Debug: 41 176771 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 42 178776 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received $qSupported:multiprocess+;swbreak+;hwbreak+;qRelocInsn+;fork-events+;vfork-events+;exec-events+;vContSupported+;QThreadEvents+;no-resumed+#df
Debug: 43 178776 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 44 180786 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received $qSupported:multiprocess+;swbreak+;hwbreak+;qRelocInsn+;fork-events+;vfork-events+;exec-events+;vContSupported+;QThreadEvents+;no-resumed+#df
Debug: 45 180786 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 46 184799 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received -
Debug: 47 184799 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 48 186807 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received -
Debug: 49 186807 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 50 188818 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received -
Debug: 51 188818 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 52 188819 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received +
Debug: 53 188819 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 54 188822 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received $vMustReplyEmpty#3a
Debug: 55 188822 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 56 190934 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received $vMustReplyEmpty#3a
Debug: 57 190934 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 58 192931 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received $vMustReplyEmpty#3a
Debug: 59 192931 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 60 194939 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received $vMustReplyEmpty#3a
Debug: 61 194939 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 62 198955 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received -
Debug: 63 198955 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 64 200966 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received -
Debug: 65 200966 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 66 202971 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received -
Debug: 67 202971 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Debug: 68 202972 stlink_tcp_cmd.c:1161 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : unknown command received +
Debug: 69 202972 stlink_tcp_cmd.c:1163 process_stlink_tcp_cmd(): process_stlink_tcp_cmd : returned value 0 unknown_command
Error: 70 202973 common.c:391 process_read_event(): recv returned 0. Remote side has closed gracefully. Good.
Debug: 71 202973 stlink_connection.c:148 evaluate_auto_kiil(): not ask to exit() because 0
IDE reports:
Failed to execute MI command:
target remote arch00:61234
Error message from debugger back end:
Remote replied unexpectedly to 'vMustReplyEmpty': timeout
Looks like there is some sort of a protocol mismatch, but I am not sure what is missing.
Thank you,
Eric
- Labels:
DEBUG
STM32CubeIDE
‎2019-12-09 1:57 AM
I think it's because you're trying to start stlink-server and you should start ST-LINK_gdbserver.
‎2019-12-09 6:18 AM
Markus,
Thank you for your reply. I was thinking this direction as well, however, it is not clear what stlink-server package use case is. But I am curious if st-link_gdbserver is available as a standalone package for linux? Perhaps I can check what is in the linux package for STM32CubeIDE and try to extract gdbserver from there, as I am currently not planning to install X on my headless linux box.
Thanks,
Eric
‎2019-12-10 2:47 AM
To my knowledge I don't think stlink-server is really meant to be called standalone, it gets called by CubeIDE. We don't distribute the gdb server standalone but we might in the future, it has been discussed. For now it's shipped with the installation of CubeIDE and located at:
/opt/st/stm32cubeide_1.1.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_1.1.0.201910081157/tools/bin/
‎2019-12-20 10:49 AM
For the love of all that is right, PLEASE release a gdbserver for Linux. I am completely stalled in working with the STM32G031 because I can't get the OpenOCD patches to work and I don't have (or want) Windows. I will never understand why chip vendors don't start with a multi-arch gdbserver and then layer the GUIs on later.
‎2022-12-28 10:42 AM
They do release a gdbserver for Linux, and they gave you the path. For the release current as of today (12/2022) it is at:
$ ls -lR /opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104
/opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104:
total 28
-rw-rw-r-- 1 root root 6053 Nov 22 05:07 about.html
-rw-rw-r-- 1 root root 551 Nov 22 05:07 fragment.properties
-rw-rw-r-- 1 root root 1337 Nov 22 05:07 fragment.xml
drwxrwxr-x 2 root root 4096 Dec 19 14:31 icons
drwxrwxr-x 2 root root 4096 Dec 19 14:31 META-INF
drwxrwxr-x 4 root root 4096 Dec 19 14:30 tools
/opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104/icons:
total 4
-rw-rw-r-- 1 root root 411 Nov 22 05:07 STM32CubeIDE_icon_32px.png
/opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104/META-INF:
total 8
-rw-rw-r-- 1 root root 728 Nov 22 05:15 MANIFEST.MF
-rw-rw-r-- 1 root root 1434 Nov 22 05:15 p2.inf
/opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104/tools:
total 8
drwxrwxr-x 3 root root 4096 Dec 19 14:31 bin
drwxrwxr-x 2 root root 4096 Dec 19 14:31 doc
/opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104/tools/bin:
total 3652
-rw-rw-r-- 1 root root 619 Nov 22 05:08 49-stlinkv2-1.rules
-rw-rw-r-- 1 root root 491 Nov 22 05:08 49-stlinkv2.rules
-rw-rw-r-- 1 root root 883 Nov 22 05:08 49-stlinkv3.rules
-rw-rw-r-- 1 root root 3185 Nov 22 05:08 config.txt
drwxrwxr-x 3 root root 4096 Dec 19 14:30 native
-rwxrwxr-x 1 root root 1811176 Nov 22 05:08 ST-LINK_gdbserver
-rwxrwxr-x 1 root root 44 Nov 22 05:08 ST-LINK_gdbserver.sh
-rw-rw-r-- 1 root root 1898172 Nov 22 05:08 STLinkUpgrade.jar
/opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104/tools/bin/native:
total 4
drwxrwxr-x 2 root root 4096 Dec 19 14:31 linux_x64
/opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104/tools/bin/native/linux_x64:
total 32
-rwxrwxr-x 1 root root 31144 Nov 22 05:08 libSTLinkUSBDriver.so
/opt/st/stm32cubeide_1.11.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.400.202209281104/tools/doc:
total 264
-rw-rw-r-- 1 root root 267441 Nov 22 05:08 DM00613038.pdf
[10:41am] [mac@lexington] /home/mac/Build/stm32/stlink>
