No connection logging in
Danoontje
I am trying to download some packages from CubeMX but i need to login to do that. When trying to open the login screen i get this errer:
i have tried everything in the connection parameters tab.
and everything gives a green checkmark when i check for connection. But i still cannot login.
mƎALLEm
Dear all,
Seems the issue has been solved please check on your side.
6 REPLIES 6
mƎALLEm
Same behavior as this thread: https://community.st.com/t5/stm32cubeide-mcus/i-can-t-log-in-myst/td-p/673955
streb2001
Lots of people having this problem at the moment. ST are worryingly silent about it.
@streb2001
Already escalated internally. See my comment in this thread.
Ghofrane GSOURI
Hello @Danoontje
First let me thank you for posting.
The issue seems to be linked either to the server or the tool network connection settings.
The possibility of having issue with the server is under investigation.
Please follow the steps from the article bellow to set the tool correctly.
How to set the network connection parameters for S... - STMicroelectronics Community
KR,
Ghofrane
mƎALLEm
Dear all,
Yes! I managed to log in on STM32CubeMX. Thanks for fixing.
