myST Login issue in STM32CubeIDE
2023-07-18 9:46 AM - edited 2023-07-18 11:01 AM
I just updated from 1.12.0 to 1.13.0 and now when i save changes it asks me to sign in to mySt to download a software package.
When i try to login to my ST i get this error:
I am on my work network, not sure if that matters. My internet is working fine with everything else but the STMCubeIDE
Thank you,
2024-05-16 8:12 AM
Please note my last post to Winfried above. Should be everything you need to get going. Good luck!
-Kryten
2024-05-20 6:44 AM
Thanks for your answer, Kryten, but I think that such a basic functionality needs to work.
Today I could log in. Apparently, they had something broken in their servers.
2024-05-20 9:22 AM
Thanks for your help
WInfried
2024-12-09 12:08 AM
Thanks for helping but
can you give me some details about this?
"In STM32CubeIDE navigating to ‘Manage Embedded MCU Packages’ and installing local package. Point to zip file on your drive".
I cannot spot where this option is hidden and I have the same problem being unable to connect to MY ST
2025-03-14 6:47 PM
I had a same problem. I tried to @Peter BENSCH 's solutions. Here is what i did;
Active Provider : " Manuel "
and st select automatically " http / https / socks " and "local hosts / 127. ...... "
it worked.
But i believe that you have to quick explain what is " manuel / direct / manuel " options meaning. That wold be great to understand why we are choosing which one is correct.
Thanks,
2025-04-18 11:30 AM
Hi @Peter BENSCH
This solution is not working. Can you please help to provide clear instructions to fix this issue ?
Arun
2025-04-22 7:44 AM
Please see this Knowledge base article.
As already mentioned in this thread, it is also possible that access to e.g. .st.com and .eclipse.org must be explicitly whitelisted in the company firewall.
Good luck!
/Peter
- « Previous
- Next »
