MacOS Install queries
‎2019-06-14 6:05 AM
Installing the latest STM32CubeIDE on mac is problematic.
I am running MacOS 10.14.5 (Mojave)
The install for ST-LINK Server fails with an error about it being incompatible and harmful.
If I selected "New STM32 Project" then the following dialog appears, and just sits there indefinitely. You cannot click on OK or CANCEL and nothing works from now on.
STM32CubeIDE
‎2019-06-17 4:14 AM
On the "Install Anyway" thing, that's a known issue and is listed in the release note.
As to the check for update macOS bug, there's a ticket for it. You can hopefully use this workaround in the meantime.
Let me know if it works!
‎2019-06-17 4:14 AM
‎2019-06-17 4:17 AM
Thanks. After a while, and a number of re-launches, it just started working.
