Linked Files
‎2025-03-30 12:13 AM
I'm working on a project that will be using shared code files from outside the project. I do not want to copy them, instead I want to link to them. I discovered how to do this and it works well. Since I don't want to make any changes to any of the linked files, I would like for the IDE to somehow make easy for me to know that the file I am currently viewing is a linked file. I have not been able to find a way to do this with CubeIDE. Does anyone know of a way? Thanks
- Labels:
STM32CubeIDE
‎2025-04-01 3:32 PM - edited ‎2025-04-01 3:32 PM
Hi @RLein.1 Yes, I think this belongs to the general Eclipse features. If you know Java you can develop this yourself, or sponsor development of add-in, optionally offer it via the "marketplace".
Eclipse is complicated and takes time to get used to it.
‎2025-04-01 4:04 PM
I believe this should be last question. :)
If I manage to get this change made in Eclipse, how does it migrate into CubeIDE?
‎2025-04-05 5:16 AM
Every so often the CubeIDE version of Eclipse gets rebased from upstream. You can politely ask ST to get this update ASAP. If this were implemented as add-on, such add-on possibly could support a range of Eclipse versions, including the current CubeIDE.
- « Previous
- 1
- 2
- Next »
