LAN9353 using STM32H743
Vani_123
Edited by a ST moderator: Please kindly don't use capital letter as it gives the impression of "shouting"
Hi Team,
I am using stm32h743 to interface lan9353 (3 port ic). for the first step if i connect one end of the ethernet cable to board and another end is connected to pc. the led is not blinking on both sides. if i check the command prompt the ethernet is not connected only. why is there any process for this please send me.
0 REPLIES 0
