How to remove error like 'COM port is not available even it is available'.
Mohan1
Hi, I am using STM32CubeIDE and written a code of transmission .I am taking data in MATLAB serially .First time when ,i run the program in STM32CubeIDE and get correct data in MATLAB by running the MATLAB serial code
//MATLAB serial code
s=serial('COM5','BaudRate',9600);
fopen(s);
data=fscanf(s);
d23=str2num(data)
x=plot(d23);
,but second time when i run the program which is written in MATLAB to get data from COM port,it shows error like 'COM port is not available '.So now what i am doing is closing the MATLAB window and again opening ,that time program in MATLABworks.Please tell me any suggestion over it.
6 REPLIES 6
Perhaps fclose() the stream?
Thanks for your quick response sir,sorry sir i am not getting what are you saying?
Close the resources you open, as you probably can't open them a second time.
fopen(s); // Open stream
fclose(s); // Close when done
i used it sir but facing same problem again.
Perhaps a problem more deeply inside MATLIB implementation, discuss with their support team or related forums.​
ok sir,thank you.
