how can ı run f429zı examples code in stm32cubeIDE
Akılı.1
in zip folder show me on eclipse
5 REPLIES 5
MM..1
Chief III
??? Is example for/from CubeIDE or other or multi IDE.
If is CubeIDE based then unzip it to new folder and double click on .project file. (Ofcourse if is your environment set for this double clik)
Installing the repository and using the Example Selector is going to be the easiest route.
File -> New -> STM32 Project -> Example Selector.
When ı make this order ı cant find example code about my board
When make this all define but withot useing openocd we cant see anyrhing on terminal to confirm what we did
Show a screenshot.
I'm not sure what you mean.
