hardfault handler
I was using stm32 cube mx to configure a pin to toggle the led so code generated using cube mx and then i just wrote the required function to toggle the led but once the code is compiled it shows zero errrors. when i debugged it and started running the code it goes to the hardfault handler where using the fault analyzer i came to know its a bus fault error and the kind of error is imprecise error. what am i supposed to avoid this errror
