Flash the .HEX file using CAN
NANWA.1
Dera Team,
Could you please help me regarding to flash the .HEX file using CAN?
N.Anwar
mÆŽALLEm
Not sure I understood your question. Do you mean how to upload hex file to an MCU using CAN?
In that case it’s possible using the bootloader. You beed to check the application note AN2606 to check this possibility on your device.
mÆŽALLEm
