Error on debug after repeated debugging sessions "Failed to execute MI command: monitor reset core"
Tobe
Senior III
i never had to much trouble with errors while debugging. But its getting exessive.
It only happens, when i debug a session, after i had already debugged a session. It makes no difference, if i manually terminate the last session before. I already tried different reset methods, which seemed to have no effect either.
It only applies to starting the debug session with the "bug" button (which would include the rebuild).
Sometimes i have to restart the IDE to make it work again.
I never had such problems before, and i did not really change much with the settings.
This issue is not present, when using a Nucleo board, but there is another issue (hard fault on debug only).
I am using this: https://www.st.com/en/development-tools/stlink-v3mods.html
Bought from reichelt.de
0 REPLIES 0
