edit makefile
Ebun.1
Hello
I am using stm32Cube IDE.
Where should I edit the makefile?
Thank you.
EJOHA
Normally you don't need to edit makefiles. Instead open the Project Properties and in C/C++ Build -> Settings the "Tool Settings" tab contains Assembler, Compiler, Linker configurations.
More information about STM32CubeIDE is found in the User manual here:
https://www.st.com/resource/en/user_manual/dm00629856-description-of-the-integrated-development-environment-for-stm32-products-stmicroelectronics.pdf
EJOHA
Hi, Mr. EJOHA
Thank you for helping.
Thank you for your reply.
