Creating a static-lib project I want to use the GCC flag: fvisibility=hidden
Adding this to the compiler flags it is not working.
Many thanks in advance for helpful tips!
‎2022-10-12 6:42 AM
‎2022-10-18 5:22 PM
You're making a static library (.a), not a .so. Visibility of publics applies only to exports of shared libraries.
‎2022-10-14 3:32 AM
Hello @OBorg.1​
I am trying to investigate this issue and it would be very helpful if you provide me with:
- What are you trying to achieve and why?
- Could you let us know the rest of the compiler linker settings?
I will be waiting for your feedback.
Kind regards,
Semer.
‎2022-10-14 3:46 AM
Here are the other GCC settings:
-mcpu=cortex-m4 -std=gnu11 -g3 -DDEBUG -DUSE_HAL_DRIVER -DSTM32G431xx -c -I../Drivers/CMSIS/Device/ST/STM32G4xx/Include -I../Drivers/CMSIS/Include -I../Inc -I../Drivers/STM32G4xx_HAL_Driver/Inc -I../Drivers/STM32G4xx_HAL_Driver/Inc/Legacy -I"C:\Users\TE228673\SW_Dev\STM32CubeIDE\workspace_1.7.0\KMX-D\DESIGN_DEMOS\PRIVATE_INCLUDE_FILE_TEST_LIB\Module\PrivateLogicFunctions\Inc" -I"C:\Users\TE228673\SW_Dev\STM32CubeIDE\workspace_1.7.0\KMX-D\DESIGN_DEMOS\PRIVATE_INCLUDE_FILE_TEST_LIB\Module\PublicLogicFunctions\Inc" -O0 -ffunction-sections -fdata-sections -Wall -fvisibility=hidden -v -fstack-usage --specs=nano.specs -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mthumb
I am creating a static-lib project.
This project contains a lot of functions for internal use only. These functions MUST NOT be callable from outside the static lib.
Referring the: https://gcc.gnu.org/onlinedocs/gcc/Code-Gen-Options.html#Code-Gen-Options
This can usually be achieved by simply using the GCC flag:
-fvisibility=hidden
Unfortunately, this flag does not work in my project in CubeIde.
‎2022-10-18 7:12 AM
Unfortunately I still haven't found a solution to my problem.
I am looking for a solution in CubeIDE for the following situation:
I need to create a library which:
* implemented some functions that need to be callable from outside
* numerous functions implemented that must NOT be accessible from outside
I have to integrate this library later in an executable project.
How can I achieve this?
‎2022-10-18 5:22 PM
‎2022-10-18 10:04 PM
Hello Pavel,
Many thanks for the explanations.
How is a requirement like mine implemented?
(This should be a common use case.)
‎2022-10-18 10:17 PM
Maybe some more background information will help:
The code (several libraries) that I create should later be used in various executable MCU projects (by other developers) in the simplest possible way.
In order to prevent manipulation of the code, the actual C code must not be distributed.
(Hence my idea to use .a file(s))
