Can STM32CubeIDE be used to program a device only?
The latest revs of CubeIDE work great for dev and debugging.
Now I want to turn off -g, recompile, write to device program memory and unplug.
How? Can CubeIDE even do this?
‎2020-02-23 10:15 AM
I feel like a complete ***** but darned if I can figure out how to do it.
If I should be reading a tutorial somewhere let me know. Flames accepted gratefully.
I am using Segger J-link, on a custom board. Debug configurations work fine, programming via SWIO. It works almost too well, because I haven't learned how it works.
Possible alternatives are STM32CubeProgrammer or Segger J-link commander loadbin, but the CubeIDE must be able to just load a release binary and stand back. (?)
- Labels:
STM32CubeIDE
‎2020-02-23 12:07 PM
‎2020-02-23 12:47 PM
Indeed so; I see issue 64277. Thank you KnarfB.
‎2020-03-03 8:50 AM
STM32CubeIDE 1.3.0 is already available: https://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-ides/stm32cubeide.html
‎2020-03-04 5:56 PM
Hi Amel, I tried 1.3.0 some days ago (see https://community.st.com/s/question/0D50X0000CCqGb5SQF/130-squashes-bug-64277downloadandresetwithoutgdb-thank-you-team-however-when-disconnected-from-swio-and-poweredon-the-chip-never-starts) although I am not there yet.
-If there are any specific instructions for debuggerless download please direct me to them. I did find the release notes.
-I almost expected a new menu item or button would have appeared "Download only" or similar since that is what we want. I may not be doing something right however, hence the previous point.
-I expected a Release-build/download-only Run configuration to be immune to deliberate missetting of the gdb configuration, but it is not. Again I wonder if I am using 1.3.0 as intended.
Thank you to the team for the efforts so far; CubeIDE will be the best in the industry.
‎2020-03-06 1:59 AM
Hi @Sking.2​ ,
Thanks for your feedback. I add our STM32CubeIDE experts, they can take care of your requests: @mattias norlander​ and @Markus GIRDLAND​ .
-Amel
‎2020-03-06 10:09 AM
Hi @Sking.2​ ,
"-If there are any specific instructions for debuggerless download please direct me to them. I did find the release notes."
- The CubeIDE user manual is in progress. Not yet published. We will describe this feature there too, once it is available.
"-I almost expected a new menu item or button would have appeared "Download only" or similar since that is what we want. I may not be doing something right however, hence the previous point."
- Yes, maybe a new menu items would have been more user-friendly if one comes from IAR/Keil background. But CubeIDE comes from Eclipse and we try to align to Eclipse look&feel. For better or for worse. :) From Eclipse point of view it makes sense to implement the standard "Run" button. Also the Eclipse/CDT framework simplifies this for us and give us a lot for free. Again with pros and cons.
"-I expected a Release-build/download-only Run configuration to be immune to deliberate missetting of the gdb configuration, but it is not. Again I wonder if I am using 1.3.0 as intended."
- Not sure about what you mean with immune. In the Eclipse world both the "Run function"and the "Debug function" is derived from the launch configuration (.launch-file). So this data is shared --> not immune?!
Does this answers your questions?!
