STM32Cube for Visual Studio Code (MCUs)
Ask questions on the STM32Cube for VSCode extension. Find answers on a variety of topics, including build issues, debug functionalities, CMake project integration, and feature requests for CubeCLT installation.
vcpkg configuration
Hello,Every time I try to import a project to VSCode I get the following vcpkg configuration error:read_contents("C:\Users\<username>\AppData\Roaming\Code\User\globalStorage\ms-vscode.vscode-embedded-tools\vcpkg\root\scripts\vcpkgTools.xml"): no such...
CRebe.1 by Associate II
  • 8548 Views
  • 11 replies
  • 1 kudos
Resolved! Printf Retarget only works with syscalls.c
I'm using STM32F7xx for my project where I use VS Code text editor in combination with CMake project build. I also use CubeMX for code generation. When I generate code using STM32CubeIDE template, the 'syscalls.c' file is generated. It provides the f...
lgacnik97 by Associate III
  • 3202 Views
  • 3 replies
  • 4 kudos
Can't import MP1 project
I have installed the STM32VSCode extension, which can successfully import H7 projects from CubeIDE. But when I import the MP157 project, it prompts:Project import failed. Unable to determine CPU type from target" STM32MP157DAAx ".Does the STM32 VSCod...
ccc by Associate
  • 1195 Views
  • 0 replies
