Why does the USB mouse not work on STM32MP157 USB1?
SunnyGeGe
We have a design with a USB HOST, the schematic is shown below, And the system is Linux 4.19. We have add some configuration about USB HID as below:
 2 CONFIG_HID=y
 3 CONFIG_HID_GENERIC=y
 4 CONFIG_USB_HID=y
 5 CONFIG_USB_HIDDEV=y
 6 CONFIG_USB_KBD=y
 7 CONFIG_USB_MOUSE=y
If we connect the USB Mouse directly to J4, it does not work(The LED on the USB mouse is on), but the USB Stick works;
dmesg | grep usb
[  0.295912] usbcore: registered new interface driver usbfs
[  0.295998] usbcore: registered new interface driver hub
[  0.296136] usbcore: registered new device driver usb
[  0.423062] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.1
[  0.423179] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.2
[  0.423306] stm32-usbphyc 5a006000.usbphyc: Dropping the link to regulator.2
[  0.423416] stm32-usbphyc 5a006000.usbphyc: Dropping the link to regulator.1
[  2.002834] usbcore: registered new interface driver pegasus
[  2.008366] usbcore: registered new interface driver asix
[  2.013858] usbcore: registered new interface driver ax88179_178a
[  2.019882] usbcore: registered new interface driver cdc_ether
[  2.025676] usbcore: registered new interface driver smsc75xx
[  2.031460] usbcore: registered new interface driver smsc95xx
[  2.037136] usbcore: registered new interface driver net1080
[  2.042849] usbcore: registered new interface driver cdc_subset
[  2.048703] usbcore: registered new interface driver zaurus
[  2.054357] usbcore: registered new interface driver cdc_ncm
[  2.083863] usbcore: registered new interface driver usb-storage
[  2.535359] typec_stusb 2-0028: STUSB driver registered
[  2.830866] usbcore: registered new interface driver usbhid
[  2.835246] usbhid: USB HID core driver
[  3.131030] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.1
[  3.137157] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.2
[  3.144451] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.12
[  3.152880] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[  3.159739] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_d not found, using dummy regulator
[  3.172019] dwc2 49000000.usb-otg: Linked as a consumer to regulator.0
[  3.178410] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_a not found, using dummy regulator
[  3.199883] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[  3.207419] ehci-platform 5800d000.usbh-ehci: EHCI Host Controller
[  3.212250] ehci-platform 5800d000.usbh-ehci: new USB bus registered, assigned bus number 1
[  3.220936] ehci-platform 5800d000.usbh-ehci: irq 73, io mem 0x5800d000
[  3.249624] ehci-platform 5800d000.usbh-ehci: USB 2.0 started, EHCI 1.00
[  3.629613] usb 1-1: new high-speed USB device number 2 using ehci-platform
[  3.831585] usb-storage 1-1:1.0: USB Mass Storage device detected
[  3.842489] scsi host0: usb-storage 1-1:1.0
[  12.021335] usbcore: registered new interface driver uas
If we connect a USB Hub to J4, and connect the USB Mouse to the USB hub, it works.
==log with usb hub and USB Mouse is connected to the USB hub ==================
root@myir:~# dmesg | grep usb
[  0.295932] usbcore: registered new interface driver usbfs
[  0.296016] usbcore: registered new interface driver hub
[  0.296160] usbcore: registered new device driver usb
[  0.422977] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.1
[  0.423097] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.2
[  0.423225] stm32-usbphyc 5a006000.usbphyc: Dropping the link to regulator.2
[  0.423338] stm32-usbphyc 5a006000.usbphyc: Dropping the link to regulator.1
[  2.011997] usbcore: registered new interface driver pegasus
[  2.017517] usbcore: registered new interface driver asix
[  2.022947] usbcore: registered new interface driver ax88179_178a
[  2.028993] usbcore: registered new interface driver cdc_ether
[  2.034865] usbcore: registered new interface driver smsc75xx
[  2.040610] usbcore: registered new interface driver smsc95xx
[  2.046291] usbcore: registered new interface driver net1080
[  2.052004] usbcore: registered new interface driver cdc_subset
[  2.057861] usbcore: registered new interface driver zaurus
[  2.063522] usbcore: registered new interface driver cdc_ncm
[  2.093019] usbcore: registered new interface driver usb-storage
[  2.545331] typec_stusb 2-0028: STUSB driver registered
[  2.840784] usbcore: registered new interface driver usbhid
[  2.845161] usbhid: USB HID core driver
[  3.139937] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.1
[  3.145998] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.2
[  3.158710] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.12
[  3.166786] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[  3.173934] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_d not found, using dummy regulator
[  3.181674] dwc2 49000000.usb-otg: Linked as a consumer to regulator.0
[  3.187993] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_a not found, using dummy regulator
[  3.209463] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[  3.217087] ehci-platform 5800d000.usbh-ehci: EHCI Host Controller
[  3.221928] ehci-platform 5800d000.usbh-ehci: new USB bus registered, assigned bus number 1
[  3.230596] ehci-platform 5800d000.usbh-ehci: irq 73, io mem 0x5800d000
[  3.259592] ehci-platform 5800d000.usbh-ehci: USB 2.0 started, EHCI 1.00
[  3.639579] usb 1-1: new high-speed USB device number 2 using ehci-platform
[  4.199627] usb 1-1.2: new low-speed USB device number 3 using ehci-platform
[  4.360210] input: PixArt USB Optical Mouse as /devices/platform/soc/5800d000.usbh-ehci/usb1/1-1/1-1.2/1-1.2:1.0/0003:093A:2510.0001/input/input3
[  4.372427] hid-generic 0003:093A:2510.0001: input: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-5800d000.usbh-ehci-1.2/input0
AntonioST
I suspect the OHCI is not enabled, but "dmesg | grep usb" does not show it. You should try "dmesg | grep -i ohci"
The wiki page
https://wiki.st.com/stm32mpu/wiki/USBH_device_tree_configuration
reports the settings for enabling ohci.
Please note that ohci is not enabled on the ST boards because both include on-board a USB hub.
4 REPLIES 4
AntonioST
The wiki page
AntonioST
By the way ... could you please provide the P/N of L3 ?
Thanks!
Thank you for your reply, AntonioST!
After enabling ohci, the USB mouse works.
The P/N of L3 is shown below.0690X00000AQzlUQAT.png
