stm32mp157a + ar8035 ,eth0 can't work properly
xxiao.1
sdk: 3.0.0 ver
kernel: 5.10.10
Ethernet cannot be connected in the kernel of version 5.10.10, but version 5.4.31 works normally
The Ethernet related device tree is as follows:
dts as follows;
&ethernet0 {
        status = "okay";
        pinctrl-0 = <&ethernet0_rgmii_pins_a>;
        pinctrl-1 = <&ethernet0_rgmii_sleep_pins_a>;
        pinctrl-names = "default", "sleep";
        phy-mode = "rgmii";
        max-speed = <1000>;
        phy-handle = <&phy0>;
        nvmem-cells = <&ethernet_mac_address>;
        nvmem-cell-names = "mac-address";
        mdio0 {
//                      reset-gpios = <&gpiog 0 GPIO_ACTIVE_LOW>;
//                      reset-duration = <200>;
                        #address-cells = <1>;
                        #size-cells = <0>;
                        compatible = "snps,dwmac-mdio";
                        phy0: ethernet-phy@6 {
                                        reg = <6>;
dmesg log as follows:
[    4.133408] systemd[1]: System time before build time, advancing clock.
[    6.200429] NET: Registered protocol family 10
[    6.253839] Segment Routing with IPv6
[    6.291489] systemd[1]: systemd 247 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK -SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ -LZ4 -ZSTD -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    6.313175] systemd[1]: Detected architecture arm.
[    6.383833] systemd[1]: Set hostname to <mc-printer>.
[    7.212762] systemd[1]: Queued start job for default target Multi-User System.
[    7.273292] systemd[1]: Created slice system-modprobe.slice.
[    7.315180] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.352904] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.392807] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.433008] systemd[1]: Reached target Paths.
[    7.462428] systemd[1]: Reached target Remote File Systems.
[    7.502287] systemd[1]: Reached target Slices.
[    7.532420] systemd[1]: Reached target Swap.
[    7.573156] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.581202] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.623519] systemd[1]: Listening on Journal Socket.
[    7.663889] systemd[1]: Listening on Network Service Netlink Socket.
[    7.703797] systemd[1]: Listening on udev Control Socket.
[    7.743323] systemd[1]: Listening on udev Kernel Socket.
[    7.783604] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    7.797464] systemd[1]: Mounting POSIX Message Queue File System...
[    7.839723] systemd[1]: Mounting Kernel Debug File System...
[    7.879416] systemd[1]: Mounting Kernel Trace File System...
[    7.920730] systemd[1]: Mounting Temporary Directory (/tmp)...
[    7.960174] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    8.019389] systemd[1]: Starting Load Kernel Module configfs...
[    8.059383] systemd[1]: Starting Load Kernel Module fuse...
[    8.092664] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.113030] systemd[1]: Starting Journal Service...
[    8.147432] systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
[    8.161475] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.214636] systemd[1]: Starting Apply Kernel Variables...
[    8.220899] EXT4-fs (mmcblk1p6): re-mounted. Opts: (null)
[    8.259090] systemd[1]: Starting Coldplug All udev Devices...
[    8.328695] systemd[1]: Mounted POSIX Message Queue File System.
[    8.364426] systemd[1]: Mounted Kernel Debug File System.
[    8.403315] systemd[1]: Started Journal Service.
[    8.857774] systemd-journald[111]: Received client request to flush runtime journal.
[    8.899170] systemd-journald[111]: File /var/log/journal/7ed74cbb68864e24a4224adbaf2dac03/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   10.201362] systemd-journald[111]: File /var/log/journal/7ed74cbb68864e24a4224adbaf2dac03/user-1003.journal corrupted or uncleanly shut down, renaming and replacing.
[   11.092287] systemd-journald[111]: File /var/log/journal/7ed74cbb68864e24a4224adbaf2dac03/user-1004.journal corrupted or uncleanly shut down, renaming and replacing.
[   11.385051] stm32-hash 54002000.hash: will run requests pump with realtime priority
[   11.482768] stm32-hash 54002000.hash: Init HASH done HW ver 23 DMA mode 1
[   11.816408] stm32-crc32 58009000.crc: Initialized
[   14.023643] 8021q: 802.1Q VLAN Support v1.8
[   14.252262] etnaviv etnaviv: bound 59000000.gpu (ops gpu_ops [etnaviv])
[   14.257465] etnaviv-gpu 59000000.gpu: model: GC400, revision: 4652
[   14.302651] etnaviv-gpu 59000000.gpu: Need to move linear window on MC1.0, disabling TS
[   14.332750] [drm] Initialized etnaviv 1.3.0 20151214 for etnaviv on minor 0
[   14.968889] Bluetooth: Core ver 2.22
[   14.971183] NET: Registered protocol family 31
[   15.034953] Bluetooth: HCI device and connection manager initialized
[   15.039905] Bluetooth: HCI socket layer initialized
[   15.102095] Bluetooth: L2CAP socket layer initialized
[   15.105785] Bluetooth: SCO socket layer initialized
[   15.797632] Bluetooth: HCI UART driver ver 2.3
[   15.800648] Bluetooth: HCI UART protocol H4 registered
[   15.865822] Bluetooth: HCI UART protocol Broadcom registered
[   16.003634] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   16.015360] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   16.303090] Bluetooth: hci0: BCM: chip id 121
[   16.306479] Bluetooth: hci0: BCM: features 0x0e
[   16.311817] Bluetooth: hci0: BCM4359C0
[   16.314382] Bluetooth: hci0: BCM4359C0 (003.001.006) build 0000
[   16.360988] Bluetooth: hci0: BCM4359C0 'brcm/BCM4359C0.hcd' Patch
[   17.094771] Bluetooth: hci0: BCM43596 UART 37.4MHz AMPAK AP6359S2 CL2[Version: Version: 0149.0331]
[   17.102426] Bluetooth: hci0: BCM4359C0 (003.001.006) build 0331
[   17.221839] systemd-journald[111]: File /var/log/journal/7ed74cbb68864e24a4224adbaf2dac03/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[   17.440139] systemd-journald[111]: File /var/log/journal/7ed74cbb68864e24a4224adbaf2dac03/user-1001.journal corrupted or uncleanly shut down, renaming and replacing.
[   17.508557] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:06] driver [Qualcomm Atheros AR8035] (irq=POLL)
[   17.542005] dwmac4: Master AXI performs any burst length
[   17.545958] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[   17.582045] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   17.626003] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[   17.638891] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii link mode
[   17.662361] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4359-sdio for chip BCM4359/9
[   17.673022] cryptd: max_cpu_qlen set to 1000
[   17.689479] 8021q: adding VLAN 0 to HW filter on device eth0
[   17.707697] stm32-dwmac 5800a000.ethernet eth0: Adding VLAN ID 0 is not supported
[   17.952630] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4359-sdio for chip BCM4359/9
[   17.959914] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[   17.992666] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4359/9 wl0: Apr 22 2019 15:46:28 version 9.87.51.11.31 (1140361@shgit) (r) FWID 01-e64dfcc7
[   18.962244] ieee80211 phy0: brcmf_dongle_roam: WLC_SET_ROAM_TRIGGER error (-52)
[   20.793998] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   20.801055] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   22.891077] systemd-journald[111]: File /var/log/journal/7ed74cbb68864e24a4224adbaf2dac03/user-1005.journal corrupted or uncleanly shut down, renaming and replacing.
PatrickF
did you progress meanwhile ?
from the log above, seems ethernet if OK.
Did you cross check the DTS potential changes between ecosystem V3 (kernel 5.10) and V2 (kernel 5.4) ?
I know that there was some changes regarding driving reset signal. Did you use it on your board ?
https://wiki.st.com/stm32mpu/wiki/Ethernet_device_tree_configuration#How_to_configure_a_PHY_reset_signal
Regards.
