STM32MP151CAA and some issue with SECURE-BOOT
gianlucarenzi
Hello everyone!
I am trying to bring up a custom board based with a STM32MP151 (C Variant) with OPTEE, TF-A and U-BOOT.
So far so good, but when running the FIT Image (Kernel + DTB) it fails finding the boot storage. It looks like the device-tree is not correctly parsed, because I did not find any activated/bind drivers in the kernel log dmesg during boot.
Here is the bootlog (from OPTEE/TF-A/UBOOT/FIT)
NOTICE: CPU: STM32MP151CAA Rev.Z
NOTICE: Model: STMicroelectronics custom STM32CubeMX board - openstlinux-6.1-yocto-mickledore-mp1-v23.06.21
INFO: PMIC version = 0x21
INFO: Reset reason (0x15):
INFO: Power-on Reset (rst_por)
INFO: FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000
INFO: FCONF: Reading firmware configuration information for: stm32mp_io
INFO: Using SDMMC
INFO: Instance 1
INFO: Boot used partition fsbl1
NOTICE: BL2: v2.8-stm32mp1-r1.0(debug):()
NOTICE: BL2: Built : 12:46:46, Dec 14 2023
INFO: BL2: Doing platform setup
INFO: RAM: DDR3-DDR3L 16bits 533000kHz
INFO: Memory size = 0x20000000 (512 MB)
INFO: BL2: Loading image id 1
INFO: Loading image id=1 at address 0x2ffff000
INFO: Image id=1 loaded: 0x2ffff000 - 0x2ffff1ea
INFO: FCONF: Reading FW_CONFIG firmware configuration file from: 0x2ffff000
INFO: FCONF: Reading firmware configuration information for: dyn_cfg
INFO: FCONF: Reading firmware configuration information for: stm32mp1_firewall
INFO: BL2: Loading image id 4
INFO: Loading image id=4 at address 0xde000000
INFO: Image id=4 loaded: 0xde000000 - 0xde00001c
INFO: OPTEE ep=0xde000000
INFO: OPTEE header info:
INFO: magic=0x4554504f
INFO: version=0x2
INFO: arch=0x0
INFO: flags=0x0
INFO: nb_images=0x1
INFO: BL2: Loading image id 8
INFO: Loading image id=8 at address 0xde000000
INFO: Image id=8 loaded: 0xde000000 - 0xde031bb8
INFO: BL2: Skip loading image id 9
INFO: BL2: Loading image id 2
INFO: Loading image id=2 at address 0xc0500000
INFO: Image id=2 loaded: 0xc0500000 - 0xc0511178
INFO: BL2: Skip loading image id 16
INFO: BL2: Loading image id 5
INFO: Loading image id=5 at address 0xc0100000
INFO: Image id=5 loaded: 0xc0100000 - 0xc01f5ff4
NOTICE: BL2: Booting BL32
INFO: Entry point address = 0xde000000
INFO: SPSR = 0x1d3
I/TC: Early console on UART#4
I/TC:
I/TC: Embedded DTB found
I/TC: OP-TEE version: Unknown_3.19 (gcc version 12.2.0 (GCC)) #1 Fri Dec 15 13:27:23 UTC 2023 arm
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Platform stm32mp1: flavor PLATFORM_FLAVOR - DT stm32mp151c-ek440_secure-mx.dts
I/TC: DTB enables console (non-secure)
I/TC: No power configuration found in DT
I/TC: Primary CPU switching to normal world boot
optee optee: OP-TEE: revision 3.19
U-Boot 2022.10-stm32mp-r1 (Dec 15 2023 - 14:27:44 +0100)
Board: stm32mp1 in trusted mode (st,stm32mp151c-ek440_secure-mx)
DRAM: 512 MiB
Clocks:
- MPU : 650 MHz
- MCU : 200 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
Core: 80 devices, 30 uclasses, devicetree: board
NAND: 0 MiB
MMC: STM32 SD/MMC: 0, STM32 SD/MMC: 1
Loading Environment from MMC... Invalid ENV offset in MMC, copy=0
In: serial
Out: serial
Err: serial
invalid MAC address 0 in OTP 00:00:00:00:00:00
Net: Invalid PHY interface
eqos_probe_resources() failed: -22No ethernet found.
Hit any key to stop autoboot: 0
Boot over mmc0!
switch to partitions #0, OK
mmc0 is current device
Loading Kernel
9892352 bytes read in 422 ms (22.4 MiB/s)
Loading DeviceTree
44817 bytes read in 12 ms (3.6 MiB/s)
208 bytes read in 10 ms (19.5 KiB/s)
## Warning: defaulting to text format
Kernel image @ 0xc2000000 [ 0x000000 - 0x96f200 ]
## Flattened Device Tree blob at c4000000
Booting using the fdt blob at 0xc4000000
Loading Device Tree to cfff2000, end cfffff10 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.15.5-EK20231213-46 (gianluca@gianlinux) (arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #2 SMP Fri Dec 15 14:24:27 CET 2023
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: STMicroelectronics custom STM32CubeMX board - openstlinux-6.1-yocto-mickledore-mp1-v23.06.21
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 64 MiB at 0xda000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00000000c0000000-0x00000000ddffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x00000000de000000-0x00000000dfffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000c0000000-0x00000000ddffffff]
[ 0.000000] node 0: [mem 0x00000000de000000-0x00000000dfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000c0000000-0x00000000dfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 16 pages/cpu s34060 r8192 d23284 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130112
[ 0.000000] Kernel command line: console=ttySTM0,115200 root=/dev/mmcblk0p9 ro rootfstype=ext4 noswap mem=512M earlyprintk raid=noautodetect loglevel=7
[ 0.000000] Unknown kernel command line parameters "noswap raid=noautodetect", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 395948K/524288K available (14336K kernel code, 2207K rwdata, 5520K rodata, 2048K init, 390K bss, 62804K reserved, 65536K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=1.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x4e8/0x6a4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 64.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xec2a6fa00, max_idle_ns: 440795202120 ns
[ 0.000001] sched_clock: 56 bits at 64MHz, resolution 15ns, wraps every 2199023255546ns
[ 0.008060] Switching to timer-based delay loop, resolution 15ns
[ 0.023212] Console: colour dummy device 80x30
[ 0.027764] Calibrating delay loop (skipped), value calculated using timer frequency.. 128.00 BogoMIPS (lpj=640000)
[ 0.038299] pid_max: default: 32768 minimum: 301
[ 0.043114] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050503] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059180] CPU: Testing write buffer coherency: ok
[ 0.064464] CPU0: update cpu_capacity 1024
[ 0.068599] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.075045] Setting up static identity map for 0xc0300000 - 0xc03000ac
[ 0.084010] rcu: Hierarchical SRCU implementation.
[ 0.094385] EFI services will not be available.
[ 0.099200] smp: Bringing up secondary CPUs ...
[ 0.103761] smp: Brought up 1 node, 1 CPU
[ 0.107797] SMP: Total of 1 processors activated (128.00 BogoMIPS).
[ 0.114130] CPU: All CPU(s) started in SVC mode.
[ 0.119417] devtmpfs: initialized
[ 0.137064] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.145165] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.155111] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.165326] pinctrl core: initialized pinctrl subsystem
[ 0.172858] DMI not present or invalid.
[ 0.177368] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.185997] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.196865] thermal_sys: Registered thermal governor 'step_wise'
[ 0.197162] cpuidle: using governor menu
[ 0.207479] No ATAGs?
[ 0.209854] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.217954] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.227924] Serial: AMBA PL011 UART driver
[ 0.243642] /soc/interrupt-controller@5000d000: bank0
[ 0.248824] /soc/interrupt-controller@5000d000: bank1
[ 0.253922] /soc/interrupt-controller@5000d000: bank2
[ 0.294025] iommu: Default domain type: Translated
[ 0.298952] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.305784] vgaarb: loaded
[ 0.309471] SCSI subsystem initialized
[ 0.313939] usbcore: registered new interface driver usbfs
[ 0.319642] usbcore: registered new interface driver hub
[ 0.325059] usbcore: registered new device driver usb
[ 0.331416] pps_core: LinuxPPS API ver. 1 registered
[ 0.336421] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.345672] PTP clock support registered
[ 0.349817] EDAC MC: Ver: 3.0.0
[ 0.356997] clocksource: Switched to clocksource arch_sys_counter
[ 1.703965] NET: Registered PF_INET protocol family
[ 1.709192] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.717463] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.725906] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.733787] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.741075] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.747612] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.754219] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.761472] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.768125] RPC: Registered named UNIX socket transport module.
[ 1.774094] RPC: Registered udp transport module.
[ 1.778904] RPC: Registered tcp transport module.
[ 1.783636] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.790140] PCI: CLS 0 bytes, default 64
[ 1.795395] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.805265] Initialise system trusted keyrings
[ 1.810115] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 1.825741] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.832855] NFS: Registering the id_resolver key type
[ 1.838059] Key type id_resolver registered
[ 1.842270] Key type id_legacy registered
[ 1.846440] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.853233] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.860737] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.865781] Key type asymmetric registered
[ 1.869956] Asymmetric key parser 'x509' registered
[ 1.874998] bounce: pool size: 64 pages
[ 1.878964] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.886405] io scheduler mq-deadline registered
[ 1.890985] io scheduler kyber registered
[ 1.989793] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[ 2.000804] SuperH (H)SCI(F) driver initialized
[ 2.006200] msm_serial: driver initialized
[ 2.010398] STMicroelectronics ASC driver initialized
[ 2.017027] STM32 USART driver initialized
[ 2.041129] brd: module loaded
[ 2.052558] loop: module loaded
[ 2.066027] libphy: Fixed MDIO Bus: probed
[ 2.072842] CAN device driver interface
[ 2.077615] bgmac_bcma: Broadcom 47xx GBit MAC driver loaded
[ 2.084191] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.089229] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.095279] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.100735] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.110207] pegasus: Pegasus/Pegasus II USB Ethernet driver
[ 2.115892] usbcore: registered new interface driver pegasus
[ 2.121711] usbcore: registered new interface driver asix
[ 2.127219] usbcore: registered new interface driver ax88179_178a
[ 2.133395] usbcore: registered new interface driver cdc_ether
[ 2.139363] usbcore: registered new interface driver smsc75xx
[ 2.145201] usbcore: registered new interface driver smsc95xx
[ 2.151052] usbcore: registered new interface driver net1080
[ 2.156789] usbcore: registered new interface driver cdc_subset
[ 2.162830] usbcore: registered new interface driver zaurus
[ 2.168530] usbcore: registered new interface driver cdc_ncm
[ 2.176543] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.183176] ehci-pci: EHCI PCI platform driver
[ 2.187734] ehci-platform: EHCI generic platform driver
[ 2.193205] ehci-omap: OMAP-EHCI Host Controller driver
[ 2.198682] ehci-orion: EHCI orion driver
[ 2.202863] SPEAr-ehci: EHCI SPEAr driver
[ 2.207080] ehci-st: EHCI STMicroelectronics driver
[ 2.212144] ehci-atmel: EHCI Atmel driver
[ 2.216307] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.222592] ohci-pci: OHCI PCI platform driver
[ 2.227161] ohci-platform: OHCI generic platform driver
[ 2.232602] SPEAr-ohci: OHCI SPEAr driver
[ 2.236777] ohci-st: OHCI STMicroelectronics driver
[ 2.241867] ohci-atmel: OHCI Atmel driver
[ 2.246475] usbcore: registered new interface driver usb-storage
[ 2.257704] i2c_dev: i2c /dev entries driver
[ 2.274917] sdhci: Secure Digital Host Controller Interface driver
[ 2.281218] sdhci: Copyright(c) Pierre Ossman
[ 2.287498] Synopsys Designware Multimedia Card Interface Driver
[ 2.295108] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.303651] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.311767] usbcore: registered new interface driver usbhid
[ 2.317459] usbhid: USB HID core driver
[ 2.327417] NET: Registered PF_INET6 protocol family
[ 2.333793] Segment Routing with IPv6
[ 2.337601] In-situ OAM (IOAM) with IPv6
[ 2.341660] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.348543] NET: Registered PF_PACKET protocol family
[ 2.353651] can: controller area network core
[ 2.358198] NET: Registered PF_CAN protocol family
[ 2.363026] can: raw protocol
[ 2.366011] can: broadcast manager protocol
[ 2.370258] can: netlink gateway - max_hops=1
[ 2.375258] Key type dns_resolver registered
[ 2.379797] ThumbEE CPU extension supported.
[ 2.384113] Registering SWP/SWPB emulation handler
[ 2.389569] Loading compiled-in X.509 certificates
[ 2.437634] Warning: unable to open an initial console.
[ 2.443776] VFS: Cannot open root device "mmcblk0p9" or unknown-block(0,0): error -6
[ 2.451695] Please append a correct "root=" boot option; here are the available partitions:
[ 2.460132] 0100 65536 ram0
[ 2.460147] (driver?)
[ 2.466282] 0101 65536 ram1
[ 2.466292] (driver?)
[ 2.472445] 0102 65536 ram2
[ 2.472456] (driver?)
[ 2.478606] 0103 65536 ram3
[ 2.478616] (driver?)
[ 2.484748] 0104 65536 ram4
[ 2.484757] (driver?)
[ 2.490908] 0105 65536 ram5
[ 2.490918] (driver?)
[ 2.497066] 0106 65536 ram6
[ 2.497077] (driver?)
[ 2.503209] 0107 65536 ram7
[ 2.503218] (driver?)
[ 2.509369] 0108 65536 ram8
[ 2.509379] (driver?)
[ 2.515511] 0109 65536 ram9
[ 2.515520] (driver?)
[ 2.521670] 010a 65536 ram10
[ 2.521680] (driver?)
[ 2.527916] 010b 65536 ram11
[ 2.527927] (driver?)
[ 2.534144] 010c 65536 ram12
[ 2.534154] (driver?)
[ 2.540390] 010d 65536 ram13
[ 2.540400] (driver?)
[ 2.546618] 010e 65536 ram14
[ 2.546628] (driver?)
[ 2.552864] 010f 65536 ram15
[ 2.552874] (driver?)
[ 2.559120] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 2.567435] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.15.5-EK20231213-46 #2
[ 2.574616] Hardware name: STM32 (Device Tree Support)
[ 2.579793] [<c0310e70>] (unwind_backtrace) from [<c030b5c0>] (show_stack+0x10/0x14)
[ 2.587612] [<c030b5c0>] (show_stack) from [<c104dc34>] (dump_stack_lvl+0x40/0x4c)
[ 2.595245] [<c104dc34>] (dump_stack_lvl) from [<c104996c>] (panic+0xf8/0x30c)
[ 2.602529] [<c104996c>] (panic) from [<c1701644>] (mount_block_root+0x168/0x208)
[ 2.610081] [<c1701644>] (mount_block_root) from [<c1701abc>] (prepare_namespace+0x150/0x18c)
[ 2.618675] [<c1701abc>] (prepare_namespace) from [<c105bc94>] (kernel_init+0x10/0x124)
[ 2.626745] [<c105bc94>] (kernel_init) from [<c0300190>] (ret_from_fork+0x14/0x24)
[ 2.634374] Exception stack(0xc20abfb0 to 0xc20abff8)
[ 2.639459] bfa0: 00000000 00000000 00000000 00000000
[ 2.647688] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.655914] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 2.662578] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
2 REPLIES 2
liaifat85
Senior III
If the filesystem is corrupted, it might prevent the kernel from mounting it. Check the filesystem integrity and potentially try to reformat and reinstall the root filesystem.
gianlucarenzi
The filesystem is good. The kernel does not find any blockdevice (nor any other driver mentioned in the device-tree blob).
In the meanwhile I have just found a little issue: in the kernel config CONFIG_OPTEE was missing. There was only CONFIG_TEE=y.
Now with the newest kernel here is the logs: (basically they differs with some more optee messages)
[ 0.000000] OF: fdt: Machine model: Eurek EK440
The device is parsed as you can see below:
[ 0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node mcuram2@10000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10041000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring1@10041000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@10042000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node mcuram@30000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node retram@38000000, compatible id shared-dma-pool
[ 0.229473] Serial: AMBA PL011 UART driver
[ 0.249820] /soc/interrupt-controller@5000d000: bank0
[ 0.255005] /soc/interrupt-controller@5000d000: bank1
[ 0.260103] /soc/interrupt-controller@5000d000: bank2
[ 4.587831] Initialise system trusted keyrings
[ 4.615730] NFS: Registering the id_resolver key type
[ 4.620949] Key type id_resolver registered
[ 4.625160] Key type id_legacy registered
[ 4.894094] STMicroelectronics ASC driver initialized
[ 4.900727] STM32 USART driver initialized
[ 5.256357] optee: probing for conduit method.
[ 5.260933] optee: revision 3.19
[ 5.261422] optee: dynamic shared memory is enabled
[ 5.270905] optee: initialized driver
[ 5.446055] VFS: Cannot open root device "mmcblk0p9" or unknown-block(0,0): error -6
[ 5.453963] Please append a correct "root=" boot option; here are the available partitions:
[ 5.462403] 0100 65536 ram0
[ 5.462417] (driver?)
[ 5.468573] 0101 65536 ram1
[ 5.468584] (driver?)
[ 5.474717] 0102 65536 ram2
[ 5.474727] (driver?)
[ 5.480877] 0103 65536 ram3
[ 5.480887] (driver?)
[ 5.487019] 0104 65536 ram4
[ 5.487028] (driver?)
[ 5.493188] 0105 65536 ram5
[ 5.493198] (driver?)
[ 5.499348] 0106 65536 ram6
[ 5.499358] (driver?)
[ 5.505490] 0107 65536 ram7
[ 5.505499] (driver?)
[ 5.511649] 0108 65536 ram8
[ 5.511659] (driver?)
[ 5.517790] 0109 65536 ram9
[ 5.517800] (driver?)
[ 5.523947] 010a 65536 ram10
[ 5.523958] (driver?)
[ 5.530193] 010b 65536 ram11
[ 5.530203] (driver?)
[ 5.536422] 010c 65536 ram12
[ 5.536431] (driver?)
[ 5.542668] 010d 65536 ram13
[ 5.542678] (driver?)
[ 5.548914] 010e 65536 ram14
[ 5.548924] (driver?)
[ 5.555144] 010f 65536 ram15
[ 5.555153] (driver?)
[ 5.561401] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 5.569714] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.15.5-EK20231218-62 #1
[ 5.576895] Hardware name: STM32 (Device Tree Support)
[ 5.582071] [<c0310e90>] (unwind_backtrace) from [<c030b5cc>] (show_stack+0x10/0x14)
[ 5.589889] [<c030b5cc>] (show_stack) from [<c1150c20>] (dump_stack_lvl+0x40/0x4c)
[ 5.597520] [<c1150c20>] (dump_stack_lvl) from [<c114c62c>] (panic+0xf8/0x30c)
[ 5.604803] [<c114c62c>] (panic) from [<c1901650>] (mount_block_root+0x168/0x208)
[ 5.612352] [<c1901650>] (mount_block_root) from [<c1901acc>] (prepare_namespace+0x154/0x190)
[ 5.620946] [<c1901acc>] (prepare_namespace) from [<c1901264>] (kernel_init_freeable+0x210/0x224)
[ 5.629888] [<c1901264>] (kernel_init_freeable) from [<c115f90c>] (kernel_init+0x10/0x124)
[ 5.638221] [<c115f90c>] (kernel_init) from [<c0300190>] (ret_from_fork+0x14/0x24)
[ 5.645849] Exception stack(0xc20adfb0 to 0xc20adff8)
[ 5.650935] dfa0: 00000000 00000000 00000000 00000000
[ 5.659165] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.667394] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 5.674059] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
Any other help? Here are my device-trees for kernel and the device-tree for scmi stuff...
Regards,
Gianluca
