STM32MP1 repo sync error while downloading distrubution package layers. error: garbage at end of loose object '543a1d1527d04f297b90ec25658f8dc71f3d0782'
Gencay
I was trying to install OpenSTLinux distribution. I am using ubuntu 20.04 for my host machine. Firstly I init repo with this command:
repo init -u <LINK FOR GIT ST OE MANIFEST > -b refs/tags/openstlinux-5.15-yocto-kirkstone-mp1-v22.06.15
then when I try to repo sync. I get following error for almost everything
fatal: loose object 543a1d1527d04f297b90ec25658f8dc71f3d0782 (stored in /home/gencay/STM32MPU_workspace/openstlinux-5.15-yocto-kirkstone-mp1-v22.06.15/.repo/project-objects/openembedded-core.git/objects/54/3a1d1527d04f297b90ec25658f8dc71f3d0782) is corrupt
openembedded-core: sleeping 4.0 seconds before retrying
Gregory PLANCHON
I did some tests but I don't have your problem.
Did you try to remove the .repo file and remake " repo init -u https://github.com/STMicroelectronics/oe-manifest.git -b refs/tags/openstlinux-5.15-yocto-kirkstone-mp1-v22.06.15 " ?
Maybe there was a problem during this part.
Grégory
6 REPLIES 6
Gregory PLANCHON
Hi @Gencay​ ,
Can I have the link of the manifest you use in order to understand where the error comes from.
regards,
Grégory
Gencay
hello,
here is the link. Thank you for your attention.
Gregory PLANCHON
Grégory
Gencay
Yes that worked thank you.
Gregory PLANCHON
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
Gencay
Okay, I am new to this thank you for heads up.
