problems with qtwebkit
VKare.1
I'm trying to create new image with my app, that needs qtwebkitwidgets, but have some problems with that. When bitbake starting compile qtwebkit-my host pc freezes. I read that post https://community.st.com/s/question/0D50X0000AVSWK1SQP/what-is-the-process-for-initializing-the-openembedded-build-environment-stexampleimageqt about qtwebkit, but in my case it doesn't work. My MACHINE=stm32mp1 DISTRO=openstlinux-x11. I tried bitbake with -k and I tried to launch compilation again, first compile stoped at 38%, after rebooting my host-it's 0% and freeze.
Is any alternative ideas how I can install qtwebkit to use my app?
Olivier GALLIEN
Hi @VKare.1​
Looks to work in this post
https://community.st.com/s/question/0D50X0000B7Ykl5SQC/getting-failure-while-compiling-qtwebkit-for-yocto
But with this conf :
DISTRO=openstlinux-eglfs MACHINE=stm32mp1-eval source layers/meta-st/scripts/envsetup.sh
bitbake st-example-image-qt
Can you make a try.
Else, what host system are you using ?
Does it fit minimal requirement for Yocto build ( cf https://wiki.st.com/stm32mpu/wiki/PC_prerequisites )
Hope it help
Olivier
Olivier GALLIEN
Olivier GALLIEN
Hi @VKare.1​
Can you make a try.
Hope it help
Olivier
Olivier GALLIEN
