No clock found for FDCAN STM32MP157D-DK1
  • November 21, 2023
  • 4 replies
  • 4745 views
First of all, I am sure I am completely overlooking something, but I can´t seem to figure this out:
In CubeIDE I added the FDCAN1 peripheral for my STM32MP157D-DK1 board. I then added the device tree to the build. However, when the board has booted up, and I type: dmesg | grep m_can, I get the message:
m_can_platform 4400e000.can: no clock found
It therefore seems that no clock has been enabled for this peripheral. How can I enable the clock?
Thanks!
Michel
PatrickF
@Hi @michelman ,
please check https://wiki.st.com/stm32mpu/wiki/STM32MP15_clock_tree#Device_tree,
As there is no FDCAN on DK1/DK2 boards, maybe you should check how it is done on EV1 board
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
michelmanAuthor
Hi Patrick,
Thank you for the reply. I created the device tree using cubeIDE, so I would assume that the device tree is correct, but please have a look, as I have the files attached.
Thank you!
Michel
PatrickF
in st,clksrc , you are missing CLK_FDCAN_xxxx (e.g. CLK_FDCAN_PLL4R).
As a consequence, you likely does not have any fdcan_k entry if you do:
cat /sys/kernel/debug/clk/clk_summary
 Regards.
Erwan SZYMANSKI
Hello @michelman ,
The answer is given in the following post : https://community.st.com/t5/stm32-mpus-products/fdcan-can-not-start-no-clock-found/m-p/618224#M10606
Kind regards,
Erwan.
