MWoło.2
Senior III
November 15, 2021
lan9303 switch device tree stm32mp1
  • November 15, 2021
  • 8 replies
  • 4237 views
Hi
I try to implement lan9303 switch with stm32mp1.
My current achievement is working only one channel
My working dts is
&ethernet0{
	pinctrl-names = "default", "sleep";
	pinctrl-0 = <&eth1_pins_mx>;
	pinctrl-1 = <&eth1_sleep_pins_mx>;
	status = "okay";
	phy-mode = "rmii";
	max-speed = <100>;
	phy-handle = <&switch>;
	nvmem-cells = <&ethernet_mac_address>;
	nvmem-cell-names = "mac-address";
	st,eth-ref-clk-sel;
	clock-names = "stmmaceth",
		"eth-ck",
		"mac-clk-tx",
		"mac-clk-rx",
		"ethstp";
	clocks = <&rcc ETHMAC>,
		<&rcc ETHCK_K>,
		<&rcc ETHTX>,
		<&rcc ETHRX>,
		<&rcc ETHSTP>;
	mdio0 {
		#address-cells = <1>;
		#size-cells = <0>;
		compatible = "snps,dwmac-mdio";
		switch: switch-phy@0 {
			compatible = "ethernet-phy-id0007.C0D1","ethernet-phy-ieee802.3-c22";
			/*compatible = "smsc,lan9303-mdio";*/
			reg = <0>;
			clocks = <&rcc ETHCK_K>;
			clock-names = "rmii-ref";
			reset-gpios = <&gpioa 4 GPIO_ACTIVE_LOW>;
			reset-duration = <100>;
			interrupt-parent = <&gpiog>;
			interrupts = <12 IRQ_TYPE_EDGE_FALLING>; /* ETH_MDINT# */
			ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						label = "cpu";
						ethernet = <&ethernet0>;
					port@1 { /* external port 1 */
						reg = <1>;
						label = "lan1";
					port@2 { /* external port 2 */
						reg = <2>;
						label = "lan2";
but works only one channel
log
[  0.000000] psci: probing for conduit method from DT.
[  1.521077] usbcore: registered new interface driver cdc_ether
[  2.821806] stm32-dwmac 5800a000.ethernet: IRQ eth_lpi not found
[  2.826787] stm32-dwmac 5800a000.ethernet: PTP uses main clock
[  2.832343] stm32-dwmac 5800a000.ethernet: no reset control found
[  2.839174] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[  2.845637] stm32-dwmac 5800a000.ethernet:  DWMAC4/5
[  2.850598] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[  2.858071] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[  2.865439] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[  2.872380] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[  2.878880] stm32-dwmac 5800a000.ethernet: TSO supported
[  2.884145] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[  2.892063] stm32-dwmac 5800a000.ethernet: device MAC address 26:b3:aa:be:d2:74
[  2.899487] stm32-dwmac 5800a000.ethernet: Enabled Flow TC (entries=2)
[  2.906093] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[  2.911986] stm32-dwmac 5800a000.ethernet: Using 32 bits DMA width
[  51.455894] using random self ethernet address
[  51.458948] using random host ethernet address
[  51.974713] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:00] driver [SMSC LAN911x Internal PHY] (irq=52)
[  52.037633] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[  52.070669] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[  52.093902] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[  52.118405] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rmii link mode
[  52.161436] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  52.212295] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
when I change to
&ethernet0{
	status = "okay";
	phy-mode = "rmii";
	max-speed = <100>;
	st,eth-ref-clk-sel;
		"eth-ck",
		"mac-clk-tx",
		"mac-clk-rx",
		"ethstp";
		<&rcc ETHCK_K>,
		<&rcc ETHTX>,
		<&rcc ETHRX>,
		<&rcc ETHSTP>;
	mdio0 {
		#size-cells = <0>;
			/*compatible = "ethernet-phy-id0007.C0D1","ethernet-phy-ieee802.3-c22";*/
			reg = <0>;
			ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						label = "cpu";
						reg = <1>;
						label = "lan1";
						reg = <2>;
						label = "lan2";
I have a result
[  2.920866] libphy: stmmac: probed
[  3.046999] LAN9303_MDIO stmmac-0:00: Found LAN9303 rev. 1
[  3.426832] LAN9303_MDIO stmmac-0:00: Found LAN9303 rev. 1
[  3.465957] LAN9303_MDIO stmmac-0:00: Using legacy PHYLIB callbacks. Please migrate to PHYLINK!
[  3.475721] LAN9303_MDIO stmmac-0:00 lan1 (uninitialized): PHY [dsa-0.0:01] driver [SMSC LAN911x Internal PHY] (irq=POLL)
[  3.487748] LAN9303_MDIO stmmac-0:00 lan2 (uninitialized): PHY [dsa-0.0:02] driver [SMSC LAN911x Internal PHY] (irq=POLL)
[  3.500408] LAN9303_MDIO stmmac-0:00: LAN9303 MDIO driver loaded successfully
[  69.119209] stm32-dwmac 5800a000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
What I do wrong?
Best answer by MWoło.2
DSA switch works. For my purpose, I don't need to add a LAN9303 driver. Just LAN911x is sufficient enough. Finally, I understand that this switch works like a daisy chain connection. The conclusion is
&ethernet0{
	status = "okay";
	phy-mode = "rmii";
	max-speed = <100>;
	phy-handle = <&phy0>;
	st,eth-ref-clk-sel;
		"eth-ck",
		"mac-clk-tx",
		"mac-clk-rx",
		"ethstp";
		<&rcc ETHCK_K>,
		<&rcc ETHTX>,
		<&rcc ETHRX>,
		<&rcc ETHSTP>;
	mdio0 {
		#size-cells = <0>;
		phy0: phy@0{
			compatible = "ethernet-phy-id0007.C0D1";
			reg = <0>;
			reset-delay-us = <10000>;
			post-reset-delay-us = <1000>;
In rootfs, I just see eth0, which works in DHCP mode. The first LAN I connect to the router and the others to a laptop, for instance. So I'm able to address the board from any devices in the system. Don't connect both LAN1 and LAN2 to the same router.
The part
switch: switch@0 {
			#size-cells = <0>;
			dsa,member = <0 0>;
			reg = <0>;
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					label = "cpu";
					reg = <1>;
					label = "lan1";
					reg = <2>;
					label = "lan2";
It is only needed when you want to filter some packets, make some bridges etc.
That is all. I think this thread/topic can be closed.
Thanks a lot
BR Michal
OlivierK
Hi MWoło.2 (Community Member)
What about the configuration mentioned in this post, it seems both LAN ports are detected using the LAN9303
&mdio0 {
phy0: ethernet-phy@0 {
compatible = "ethernet-phy-id0022.1622";
reg = <0>;
The lan9303 acts as a switch and I am able to use both LAN-Ports .
MWoło.2
MWoło.2Author
Senior III
November 16, 2021
Hi Olivier
I modified DTS to look as follow
&ethernet0{
	status = "okay";
	phy-mode = "rmii";
	max-speed = <100>;
	st,eth-ref-clk-sel;
		"eth-ck",
		"mac-clk-tx",
		"mac-clk-rx",
		"ethstp";
		<&rcc ETHCK_K>,
		<&rcc ETHTX>,
		<&rcc ETHRX>,
		<&rcc ETHSTP>;
	mdio0{
				interrupt-parent = <&gpioe>;
			reg = <0>;
and from boot I received
[  1.546962] usbcore: registered new interface driver cdc_ether
[  2.848821] stm32-dwmac 5800a000.ethernet: IRQ eth_lpi not found
[  2.853664] stm32-dwmac 5800a000.ethernet: PTP uses main clock
[  2.859410] stm32-dwmac 5800a000.ethernet: no reset control found
[  2.866064] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[  2.872497] stm32-dwmac 5800a000.ethernet:  DWMAC4/5
[  2.877586] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[  2.884917] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[  2.892257] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[  2.899222] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[  2.905688] stm32-dwmac 5800a000.ethernet: TSO supported
[  2.910885] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[  2.918842] stm32-dwmac 5800a000.ethernet: device MAC address 1e:a7:57:ce:60:73
[  2.926205] stm32-dwmac 5800a000.ethernet: Enabled Flow TC (entries=2)
[  2.932763] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[  2.938678] stm32-dwmac 5800a000.ethernet: Using 32 bits DMA width
[  68.650078] using random self ethernet address
[  68.653125] using random host ethernet address
[  69.278738] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:00] driver [Micrel KSZ9031 Gigabit PHY] (irq=POLL)
[  69.337810] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[  69.353465] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[  69.374392] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[  69.382796] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rmii link mode
[  69.409864] 8021q: adding VLAN 0 to HW filter on device eth0
[  69.409907] stm32-dwmac 5800a000.ethernet eth0: Adding VLAN ID 0 is not supported
Chip was identified as KSZ9031 according to
and of course not working.
MWoło.2
MWoło.2Author
Senior III
November 16, 2021
I also installed net-tools
and typing
mii-tool -vv eth0
I receive something
0693W00000GXnQDQA1.pngSo I'm not able to read PHY ID.
From the documentation, I read that ID is 0007.C0D1. This ID is identical to LAN911x.
MWoło.2
MWoło.2Author
Senior III
November 16, 2021
I have a strange feeling that I configured everything good and a problem is related to configuration DSA(switch) into systemd.
My current boot log looks
[  1.519995] usbcore: registered new interface driver cdc_ether
[  2.824784] stm32-dwmac 5800a000.ethernet: IRQ eth_lpi not found
[  2.829640] stm32-dwmac 5800a000.ethernet: PTP uses main clock
[  2.835410] stm32-dwmac 5800a000.ethernet: no reset control found
[  2.842036] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[  2.848625] stm32-dwmac 5800a000.ethernet:  DWMAC4/5
[  2.853614] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[  2.860968] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[  2.868399] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[  2.875361] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[  2.881819] stm32-dwmac 5800a000.ethernet: TSO supported
[  2.887104] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[  2.895042] stm32-dwmac 5800a000.ethernet: device MAC address a2:6d:9e:38:f7:a6
[  2.902415] stm32-dwmac 5800a000.ethernet: Enabled Flow TC (entries=2)
[  2.909062] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[  2.914958] stm32-dwmac 5800a000.ethernet: Using 32 bits DMA width
[  51.958489] using random self ethernet address
[  51.961564] using random host ethernet address
[  53.374605] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:01] driver [SMSC LAN8710/LAN8720] (irq=52)
[  53.437576] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[  53.485457] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[  53.500961] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[  53.547373] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rmii link mode
[  53.584953] 8021q: adding VLAN 0 to HW filter on device eth0
[  53.600653] stm32-dwmac 5800a000.ethernet eth0: Adding VLAN ID 0 is not supported
The eth0 is combined somehow with VLAN. Unfortunately, I haven't enough knowledge of how to do this.
Can someone give me some links to, manual on how to do this in systems, not in busybox.
OlivierK
Just one remark. Is it specific to the LAN9303 to redefine in the mdio node:
Rgds,
Olivier
MWoło.2
MWoło.2Author
Senior III
November 19, 2021
Hi Olivier,
my current DTS looks like following
&ethernet0{
	status = "okay";
	phy-mode = "rmii";
	max-speed = <100>;
	st,eth-ref-clk-sel;
		"eth-ck",
		"mac-clk-tx",
		"mac-clk-rx",
		"ethstp";
		<&rcc ETHCK_K>,
		<&rcc ETHTX>,
		<&rcc ETHRX>,
		<&rcc ETHSTP>;
	mdio0 {
		#size-cells = <0>;
		phy0: phy@1{
			compatible = "ethernet-phy-id0007.C0D1", "ethernet-phy-ieee802.3-ac";
			reg = <1>;
		switch: switch@0 {
			#size-cells = <0>;
			dsa,member = <0 0>;
			reg = <0>;
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					label = "cpu";
					reg = <1>;
					label = "lan1";
					reg = <2>;
					label = "lan2";
my log is
[  2.969615] libphy: stmmac: probed
[  2.984053] LAN9303_MDIO stmmac-0:00: Found LAN9303 rev. 1
[  3.249640] LAN9303_MDIO stmmac-0:00: Found LAN9303 rev. 1
[  3.321255] LAN9303_MDIO stmmac-0:00: Using legacy PHYLIB callbacks. Please migrate to PHYLINK!
[  3.340418] LAN9303_MDIO stmmac-0:00 lan1 (uninitialized): PHY [dsa-0.0:01] driver [SMSC LAN911x Internal PHY] (irq=POLL)
[  3.354287] LAN9303_MDIO stmmac-0:00 lan2 (uninitialized): PHY [dsa-0.0:02] driver [SMSC LAN911x Internal PHY] (irq=POLL)
[  3.367043] LAN9303_MDIO stmmac-0:00: LAN9303 MDIO driver loaded successfully
[  54.013139] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:01] driver [SMSC LAN911x Internal PHY] (irq=52)
[  56.055846] LAN9303_MDIO stmmac-0:00 lan1: configuring for phy/gmii link mode
[  56.374405] LAN9303_MDIO stmmac-0:00 lan2: configuring for phy/gmii link mode
[ 100.075252] LAN9303_MDIO stmmac-0:00 lan2: Link is Up - 100Mbps/Full - flow control rx/tx
[ 134.085231] LAN9303_MDIO stmmac-0:00 lan1: Link is Up - 100Mbps/Full - flow control rx/tx
[ 168.715032] LAN9303_MDIO stmmac-0:00 lan2: Link is Down
[ 169.435065] LAN9303_MDIO stmmac-0:00 lan1: Link is Down
and everything seems to be work but I have a problem with VLAN filtering
[  54.130459] 8021q: adding VLAN 0 to HW filter on device eth0
[  54.130514] stm32-dwmac 5800a000.ethernet eth0: Adding VLAN ID 0 is not supported
[ 100.082137] IPv6: ADDRCONF(NETDEV_CHANGE): lan2: link becomes ready
[ 134.092101] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
[ 145.520560] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 145.528055] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 147.737539] net eth0: Dropping packet due to invalid VLAN marker
[ 147.742227] net eth0: Dropping packet due to invalid VLAN marker
[ 147.754183] net eth0: Dropping packet due to invalid VLAN marker
[ 147.758863] net eth0: Dropping packet due to invalid VLAN marker
[ 150.928970] net eth0: Dropping packet due to invalid VLAN marker
[ 150.933682] net eth0: Dropping packet due to invalid VLAN marker
[ 150.939763] net eth0: Dropping packet due to invalid VLAN marker
[ 150.945837] net eth0: Dropping packet due to invalid VLAN marker
[ 151.102514] net eth0: Dropping packet due to invalid VLAN marker
[ 151.107207] net eth0: Dropping packet due to invalid VLAN marker
[ 152.765556] lan9303_rcv: 6 callbacks suppressed
[ 152.768763] net eth0: Dropping packet due to invalid VLAN marker
[ 152.774845] net eth0: Dropping packet due to invalid VLAN marker
[ 152.781109] net eth0: Dropping packet due to invalid VLAN marker
[ 152.787024] net eth0: Dropping packet due to invalid VLAN marker
[ 152.793150] net eth0: Dropping packet due to invalid VLAN marker
[ 152.799229] net eth0: Dropping packet due to invalid VLAN marker
[ 153.417139] net eth0: Dropping packet due to invalid VLAN marker
[ 153.421823] net eth0: Dropping packet due to invalid VLAN marker
[ 153.432334] net eth0: Dropping packet due to invalid VLAN marker
[ 153.437043] net eth0: Dropping packet due to invalid VLAN marker
[ 161.525183] lan9303_rcv: 8 callbacks suppressed
[ 161.528379] net eth0: Dropping packet due to invalid VLAN marker
[ 161.534468] net eth0: Dropping packet due to invalid VLAN marker
[ 161.540766] net eth0: Dropping packet due to invalid VLAN marker
[ 161.546639] net eth0: Dropping packet due to invalid VLAN marker
[ 161.552685] net eth0: Dropping packet due to invalid VLAN marker
[ 161.558848] net eth0: Dropping packet due to invalid VLAN marker
[ 161.564941] net eth0: Dropping packet due to invalid VLAN marker
[ 161.570962] net eth0: Dropping packet due to invalid VLAN marker
[ 164.017030] net eth0: Dropping packet due to invalid VLAN marker
[ 164.021672] net eth0: Dropping packet due to invalid VLAN marker
[ 169.027536] lan9303_rcv: 6 callbacks suppressed
[ 169.030707] net eth0: Dropping packet due to invalid VLAN marker
[ 169.040067] net eth0: Dropping packet due to invalid VLAN marker
[ 175.675825] stm32-dwmac 5800a000.ethernet eth0: Link is Down
Unfortunately, I have no idea what this VLAN means. I read that LAN9303 do not support filtering but how to disable or work around this. guess that for this reason, I have not received an IP address.
Ref.
https://01.org/linuxgraphics/gfx-docs/drm/networking/dsa/lan9303.html
MWoło.2
MWoło.2Author
Senior III
November 20, 2021
VLAN warning removed by disabled options in the Kernel.
MWoło.2
MWoło.2AuthorBest answer
Senior III
November 22, 2021
&ethernet0{
	status = "okay";
	phy-mode = "rmii";
	max-speed = <100>;
	st,eth-ref-clk-sel;
		"eth-ck",
		"mac-clk-tx",
		"mac-clk-rx",
		"ethstp";
		<&rcc ETHCK_K>,
		<&rcc ETHTX>,
		<&rcc ETHRX>,
		<&rcc ETHSTP>;
	mdio0 {
		#size-cells = <0>;
		phy0: phy@0{
			reg = <0>;
The part
switch: switch@0 {
			#size-cells = <0>;
			dsa,member = <0 0>;
			reg = <0>;
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					label = "cpu";
					reg = <1>;
					label = "lan1";
					reg = <2>;
					label = "lan2";
Thanks a lot
BR Michal
