How to set THREAD_VERSION for ot-br-posix
‎2022-11-22 11:02 PM
I wants to bitbake ot-br-posix with OT_THREAD_VERSION=1.1, Modified the ot-br-posix_git.bb file, add -DOT_THREAD_VERSION=1.1 in this file. But result is ot-br-posix using Thread Version 1.2
Does somebody know how to solve this issue
Many thanks.
B.R
Frank
STM32MP15 Lines
‎2022-11-23 12:49 AM
Hi @Community member​
by looking at the file third_party/openthread/CMakeLists.txt in the GIT repository of ot-br-posix under github https://github.com/openthread/ot-br-posix, I can see that OT_THREAD_VERSION with a different value than 1.1 triggers some variables to be set. In particular (so if OT_THREAD_VERSION is NOT 1.1) :
- OT_DUA is set to ON
- OT_MLR is set to ON
I guess if OT_THREAD_VERSION is set to 1.1, these variables are set to OFF.
But that conflicts with the recipe ot-br-posix_git.bb which explicitly sets them to ON.
This would seem like a good idea to remove
-DOT_MLR=ON \
and
-DOT_DUA=ON \
from the recipe or enforce them to OFF.
Best regards,
--JM
‎2022-11-24 6:29 PM
Hi JM
Thanks a lot, I tried with your method. It does not work. The thread version sticks at version 1.2. But on rpi3 platform, only INFRA_IF_NAME=wlan0 WEB_GUI=1 BACKBONE_ROUTER=0 OTBR_OPTIONS="-DOT_THREAD_VERSION=1.1" ./script/setup, then it works.
B.R.
Frank
‎2022-11-25 5:16 AM
Too bad :(
Indeed the OT_THREAD_VERSION=1.1 is ignored as I can see it on my board in /var/log/messages:
Nov 25 14:12:32 stm32mp1 user.info otbr-agent[1386]: [INFO]-UTILS---: Thread version: 1.2.0
I need to dig into my own notes as I successfully built the ot-br-posix package some months ago but with OpenSTLinux 3.0 and a different ot-br-posix recipe:
Mar 31 08:15:46 stm32mp1 user.info otbr-agent[1060]: [INFO]-UTILS---: Thread version: 1.1.1
I agree the setup with RPi is working well but the Yocto recipe relies on a different mechanism that surely explains this discrepancy.
Best regards,
--JM
‎2022-11-25 9:58 AM
I think we need some combinations of flags to properly build the OBTR package and I didn't find them.
At now, I have added these flags:
-DOTBR_BACKBONE_ROUTER=OFF
-DOTBR_DUA_ROUTING=OFF
-DOT_DUA=OFF
-DOT_MLR=OFF
But I have some compilation errors because some features need OpenThread version 1.2. Currently, I don't know which flags allow the build process to bypass these errors.
Best regards,
--JM
‎2022-11-27 6:22 PM
Hi JM,
Thanks for your information. I will try OpenSTLinux 3.0 and try to feature out the reason.
B.R.
Frank
‎2022-11-27 11:49 PM
If you have access to a RPi3 machine, I would be curious about building the OTBR with OT_THREAD_VERSION=1.1: is RPi3 really with version 1.1 when running? Or is the version is forced silently to 1.2?
I think you can stay with DV-4.1 to search the reason why OT_THREAD_VERSION=1.1 is not taken into account. I guess this is related to interaction with the build process of third_party/openthread.
Best regards,
--JM
‎2022-11-28 12:28 AM
Hi JM,
On RPI3, I just did below:
$ git clone https://github.com/openthread/ot-br-posix
$ cd ot-br-posix
$ WEB_GUI=1 ./script/bootstrap
$ INFRA_IF_NAME=wlan0 WEB_GUI=1 BACKBONE_ROUTER=0 OTBR_OPTIONS="-DOT_THREAD_VERSION=1.1" ./script/setup
If without OTBR_OPTIONS="-DOT_THREAD_VERSION=1.1", the ot-br-posix uses thread version 1.3
Best Regards
Frank
‎2022-11-28 1:07 AM
Thank you for the output.
Do you have the same output when building OTBR with OT_THREAD_VERSION=1.1 please?
Best regards,
--JM
‎2022-11-28 9:26 PM
Hi JM,
When building ot-br-posix on RPI3, the build process outputs
+ local builddir=/home/pi/work/ot-br-posix/build/otbr
+ mkdir -p /home/pi/work/ot-br-posix/build/otbr
+ cd /home/pi/work/ot-br-posix/build/otbr
+ cmake -GNinja /home/pi/work/ot-br-posix -DBUILD_TESTING=OFF -DCMAKE_INSTALL_PREFIX=/usr -DOTBR_DBUS=ON -DOTBR_FEATURE_FLAGS=ON -DOTBR_DNSSD_DISCOVERY_PROXY=ON -DOTBR_SRP_ADVERTISING_PROXY=ON -DOTBR_INFRA_IF_NAME=wlan0 -DOTBR_MDNS=mDNSResponder -DOTBR_VERSION= -DOT_PACKAGE_VERSION= -DOT_THREAD_VERSION=1.1 -DOTBR_WEB=ON -DOTBR_BORDER_ROUTING=ON -DOTBR_REST=ON
And the otbt-agent runs with Thread Version 1.1.1, it works with our STM32WB55 RCP
Best Regards
Frank
