Support for BlueZ in the STM32MPU distribution package?
‎2021-08-24 11:03 AM
Hello ,
Is the BlueZ supported or added in the Distribution or developer or starter image?
I tried running bluetoothd -v to get the version of the bluetoothd (and hence the Bluez which has this demon built) but I got this :
root@stm32mp1:~# bluetoothd -v
-sh: bluetoothd: not found
I then tried building the Distribution package which has this meta-connectivity layer where there is BlueZ is in add on Recipes ( https://wiki.st.com/stm32mpu/wiki/STM32MP15_OpenSTLinux_release_note)
bluez5meta-st/meta-st-openstlinux/recipes-connectivity/bluez5/bluez5_%.bbappend
Do I have to add this layer? or will it be built by bitbake st-image-weston
Using bitbake st-image-weston and fishing the image gives the same result.
Please tell the steps to build and use BlueZ and all the utilities it provides (bluetoothd,meshctl)
Thanks in advance !
D
STM32MP15 Lines
‎2021-08-31 1:16 AM
Hi @darla14​
first, you need to check if your BT environment is correctly probed: https://wiki.st.com/stm32mpu/wiki/Bluetooth_overview#How_to_trace_and_debug_the_framework
From my side, after setting the BT parameters (https://wiki.st.com/stm32mpu/wiki/How_to_set_up_a_Bluetooth_connection) and following this wiki page https://wiki.st.com/stm32mpu/wiki/How_to_scan_Bluetooth_devices, I successfully paired my board STM32MPU157C-DK2 running OpenSTLinux 3.0 with my phone.
For BTLE, take a look at the wiki page https://wiki.st.com/stm32mpu/wiki/How_to_scan_BLE_devices#BLE_device_connection_step-by-step
Finally, the error message you referred to is normal as the BT daemon is already running through the systemd service:
$ systemctl status bluetooth
[0;1;32m*[[0m bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: [[0;1;32mactive (running)[[0m since Tue 2021-08-31 08:09:42 UTC; 2min 35s ago
Docs: man:bluetoothd(8)
Main PID: 571 (bluetoothd)
Status: "Running"
Memory: 2.0M
CGroup: /system.slice/bluetooth.service
`-571 /usr/libexec/bluetooth/bluetoothd
Aug 31 08:09:41 stm32mp1 systemd[1]: Starting Bluetooth service...
Aug 31 08:09:42 stm32mp1 systemd[1]: Started Bluetooth service.
Best regards,
--JM
‎2021-08-24 11:46 PM
Hi @darla14​
Bluetooth is fully supported and the bluetoothd program is installed by default in OpenSTLinux image but it is not available in your PATH environment:
root@stm32mp1:~# ps -aux | grep blue
root 572 0.0 0.6 4792 2920 ? Ss 06:31 0:00 /usr/libexec/bluetooth/bluetoothd
root 1100 0.0 0.2 2024 1112 ttySTM0 S+ 06:37 0:00 grep blue
So, the command you mentioned runs fine:
root@stm32mp1:~# /usr/libexec/bluetooth/bluetoothd -v
5.55
About the availability of the meshctl utility, please refer to the following link : https://community.st.com/s/question/0D50X0000BTdF20SQF/stm32mp157cdk2-bluetooth-mesh .
Best regards,
--JM
Edit: add link to build meshctl
‎2021-08-25 10:39 AM
Thanks for your reply. Do you know where I can find the compiled binary for
https://github.com/bluez/bluez/blob/master/test/example-gatt-server ??
or
https://github.com/bluez/bluez/blob/master/tools/gatt-service.c
D
‎2021-08-25 11:41 PM
Hi @darla14​
The two binaries are available from the package bluez5-testtools from our OpenSTLinux repository. You can install it with the command:
$ apt-get install bluez5-testtools
The compiled binaries are then in the directory /usr/lib/bluez/test
Best regards,
--JM
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'.
‎2021-08-26 10:57 AM
Thanks for the prompt reply .
Ok this works , after i did apt-get update as well before running
root@stm32mp1:/usr/lib/bluez/test# ./example-gatt-server
./example-gatt-server:394: PyGIDeprecationWarning: GObject.timeout_add is deprecated; use GLib.timeout_add instead
GObject.timeout_add(5000, self.drain_battery)
./example-gatt-server:651: PyGIDeprecationWarning: GObject.MainLoop is deprecated; use GLib.MainLoop instead
mainloop = GObject.MainLoop()
Registering GATT application...
GetManagedObjects
GATT application registered
But on the lightblue App (iPhone) , i cant see the device.What device name should I get?
Also is there way to build this using makefile if I want to customise it? How?
Since it depends on dbus and glib and bluez requires ./confgue kind of scripts to build which I am not sure is feasible for cross compiling the bluez/test-*
D
‎2021-08-27 12:08 AM
Hi @darla14​
I am glad you resolve your initial problems!
About the bluetooth usage, I recommand the following wiki : https://wiki.st.com/stm32mpu/wiki/Bluetooth_overview and its derivative pages.
For the development of applications, this wiki page https://wiki.st.com/stm32mpu/wiki/How_to_cross-compile_with_the_Developer_Package may help you.
Best regards,
--JM
‎2021-08-30 11:08 AM
Hello @Jean-Marc B​ ,
Thanks for the reply,
I am able to cross compile the utilities and run it on stm32mp1 but strangely I think I may have to enable something else .Is the bluetooth low energy enabled by default?If not what commands is needed to turn it on.
As a test I ran bluetoothctl and then scan on and I got this ,I rebooted as well :
[bluetooth]# scan on
Failed to start discovery: org.bluez.Error.NotReady
list command shows the default the MAC address :
[bluetooth]# list
Controller 43:43:A1:12:1F:AC stm32mp1 [default]
Also :
/usr/libexec/bluetooth# ./bluetoothd
D-Bus setup failed: Name already in use
Can you please tell whats wrong here?
‎2021-08-31 1:16 AM
Hi @darla14​
Status: "Running"
Memory: 2.0M
Best regards,
--JM
‎2021-08-31 10:02 AM
Thanks , it helped.I will test further !
‎2021-09-06 12:09 AM
