STM32MP131FAF7T how to program PMIC
‎2023-12-26 1:19 PM - edited ‎2023-12-26 2:36 PM
I have a custom built STM32MP131FAF7T board and can't set my VOUT2. The only line that is down is my VDD DDR Lines since I can't program my PMIC (STPMIC1DPQR) to have the VOUT2 to be 1.35 volts instead of 1.1 volts. My VCPU is at 1.2V, VDD is at 3.3V and VCORE is at 1.2V.
- Labels:
DDR
Power
STM32MP13 Lines
‎2024-01-02 6:09 AM - edited ‎2024-01-02 6:35 AM
Hi @T_Dodd ,
PMIC Buck2 is set and enable by TFA BL2 ( see drivers/st/ddr/stm32mp1_ram.c:int stm32mp1_ddr_probe(void) ) in our delivery, following content of device tree node :
pmic: stpmic@33 {
vdd_ddr: buck2 {
regulator-name = "vdd_ddr";
regulator-min-microvolt = <1350000>;
regulator-max-microvolt = <1350000>;
regulator-always-on;
regulator-over-current-protection;
standby-ddr-off {
regulator-off-in-suspend;
Did you properly set this node in your custom configuration ?
Olivier
Hi @T_Dodd ,
pmic: stpmic@33 {
vdd_ddr: buck2 {
standby-ddr-off {
Olivier
