How to program OTP on STM32MP1
2022-07-27 11:40 AM
I followed ST wiki, success to display OTP by the command:
STM32_Programmer_CLI.exe --connect port=usb1 -otp displ
Then I try to test writing a value to wordid 79 which currently is 0x00000000, and free for user.
STM32_Programmer_CLI -c port=usb1 -otp program wordID=0x4F value=0x12345678
No thing wrong, command return sucess:
I display cmd again, it is till 0x00000000, even reset the board.
Any one know what I am missing, please?
STM32MP15 Lines
2022-07-28 7:18 AM
Nothing wrong on my side on windows 10
79 | 0x00000000 | 0x00000000
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin> .\STM32_Programmer_CLI.exe -c port=usb1 -otp write word=79 value=0x12345678
STM32CubeProgrammer v2.11.0-B02
USB speed : High Speed (480MBit/s)
Manuf. ID : STMicroelectronics
Product ID : USB download gadget@Device ID /0x500, @Revision ID /0x2001, @Name /STM32MP157FAC Rev.Z,
SN : 0034002A3438511836383238
DFU protocol: 1.1
Board : --
Device ID : 0x0500
Device name : STM32MP157FAC Rev.Z
Device type : MPU
Revision ID : --
Device CPU : Cortex-A7
UPLOADING OTP STRUCTURE ...
Partition : 0xF2
Uploading OTP data:
██████████████████████████████████████████████████ 100%
OTP Partition read successfully
OTP Write command:
You are trying to write on OTP partition with the following inputs :
Word | Value
79 | 0x12345678
Lock | NO
Warning: This operation cannot be reverted and may brick your device.
Warning: Do you confirm ? [yes/no]
yes
The operation was confirmed...
WRITING TO OTP PARTITION ...
Partition : 0xF2
Downloading OTP data:
Uploading OTP data:
OTP words programming done successfully
PS C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin> .\STM32_Programmer_CLI.exe -c port=usb1 -otp displ
DFU protocol: 1.1
Board : --
Device ID : 0x0500
Device type : MPU
Revision ID : --
Partition : 0xF2
Uploading OTP data:
OTP DATA WORDS :
Struct_version :
| none : 0x00000002
BSEC_OTP_CONFIG :
|_ State : Secure Open
|_ Hardware Key Set : N
|_ Encrypted data : N
OTP REGISTERS:
ID | value | status
79 | 0x12345678 | 0x00000000
2022-07-28 2:53 AM
Hi Dat Tran (Community Member)
https://wiki.st.com/stm32mpu/wiki/STM32CubeProgrammer_OTP_management#Examples_with_STM32Programmer
Do you use OpenSTLinux DV4.0.1 (header v2)?
With a minimal flashlayout + otp displ, it should work to write and readback OTPs, ex for a MP157 DK2 board.
./STM32_Programmer_CLI -c port=usb1 -w FlashLayout_stm32mp157c-dk2.tsv
./STM32_Programmer_CLI -c port=usb1 -otp displ
2022-07-28 5:25 AM
Hi @OlivierK
I follow steps from here:
The SDK I downloaded just last week.
The board is STM32MP157F-DK2 - Discovery kit with STM32MP157F MPU - STMicroelectronics
2022-07-28 5:35 AM
And I ran STM32CubeProgrammer on win10, does it make any different?
2022-07-28 5:43 AM
Then you choose a TSV for MP157F-DK2 (not MP157C-DK2).
CubeProgrammer should work fine on both Win10 and Linux.
SDK should match your DV package you've downloaded (DV3.1 or DV4.01), but that's irrelevant here.
2022-07-28 5:59 AM
Hi @OlivierK
Hi, the screenshot I capture from wiki that why it is MP157C.
I ran on my PC it was MP157F-DK2 already. I just installed everything from last week. Should are they up to date?
Note here is, all messages are returned sucesful, no error as you see on my first post. Just value at id 79th is not updated. I selected 79 because I see all lock value is zero, that make me think is it OK to read or write.
Is 0x12345678 has any special bit that prevent to update the word id 79th ?
2022-07-28 6:01 AM
Sorry, no I don't see anything wrong. I will double check
2022-07-28 6:12 AM
@OlivierK
I tried the command line as your suggest, instead of GUI application, then I got this error, hopefully you will see something wrong in my side.
2022-07-28 7:18 AM
DFU protocol: 1.1
Board : --
Device ID : 0x0500
Device type : MPU
Revision ID : --
Partition : 0xF2
Uploading OTP data:
OTP Write command:
Word | Value
79 | 0x12345678
Lock | NO
yes
Partition : 0xF2
Uploading OTP data:
DFU protocol: 1.1
Board : --
Device ID : 0x0500
Device type : MPU
Revision ID : --
Partition : 0xF2
Uploading OTP data:
OTP DATA WORDS :
Struct_version :
| none : 0x00000002
BSEC_OTP_CONFIG :
OTP REGISTERS:
ID | value | status
2022-07-28 7:47 AM
Hi @OlivierK
I got it working. From your answer, I found the problems on my side.
The latest STM32CubePro I installed last week is v2.11.0 and located on "C:\Program Files"
The earlier version 2.5 located on "C:\Program Files (86)".
Default system point me to 2.5. I uninstalled 2.5 and point to 2.11 and now working and output same as yours
Second is, seem "word=79" works, but "wordID=79" doesn't work, (says no error).
what is different word and wordID?
Anyway, got it working, thank you so much!
