bitbake build error - package openocd
‎2024-03-22 2:01 AM
Hi ,
i'm trying to build st-image-weston for target board STM32MP135F-DK
repo init -u https://github.com/STMicroelectronics/oe-manifest.git -b refs/tags/openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23
repo sync
DISTRO=openstlinux-weston MACHINE=stm32mp13-disco source layers/meta-st/scripts/envsetup.sh
bitbake st-image-weston
.... after 4.5 hours :
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['/..../openstlinux/STM32MP1-Ecosystem/Distribution-Package/layers/openembedded-core/meta/recipes-core/gettext/gettext-minimal-native_0.21.bb:do_populate_sysroot', '/..../openstlinux/STM32MP1-Ecosystem/Distribution-Package/layers/openembedded-core/meta/recipes-devtools/libtool/libtool-native_2.4.7.bb:do_populate_sysroot', '/..../openstlinux/STM32MP1-Ecosystem/Distribution-Package/layers/openembedded-core/meta/recipes-devtools/quilt/quilt-native_0.67.bb:do_populate_sysroot', 'virtual:native:/..../openstlinux/STM32MP1-Ecosystem/Distribution-Package/layers/meta-st/meta-st-stm32mp/recipes-support/hidapi/hidapi-stm32mp_0.10.1.bb:do_populate_sysroot', 'virtual:native:/..../openstlinux/STM32MP1-Ecosystem/Distribution-Package/layers/openembedded-core/meta/recipes-devtools/autoconf/autoconf_2.71.bb:do_populate_sysroot', 'virtual:native:/..../openstlinux/STM32MP1-Ecosystem/Distribution-Package/layers/openembedded-core/meta/recipes-devtools/automake/automake_1.16.5.bb:do_populate_sysroot', 'virtual:native:/..../openstlinux/STM32MP1-Ecosystem/Distribution-Package/layers/openembedded-core/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['gettext-minimal-native', 'libtool-native', 'quilt-native', 'hidapi-stm32mp-native', 'autoconf-native', 'automake-native', 'pkgconfig-native', 'libusb-compat-native', 'texinfo-dummy-native', 'm4-native', 'gnu-config-native', 'libusb1-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function autotools_preconfigure
| DEBUG: Shell function autotools_preconfigure finished
| DEBUG: Executing python function autotools_aclocals
| DEBUG: SITE files ['endian-little', 'common-linux', 'common-glibc', 'bit-64', 'x86_64-linux', 'common']
| DEBUG: Python function autotools_aclocals finished
| DEBUG: Executing shell function do_configure
| Author identity unknown
| WARNING: exit code 128 from a shell command.
| *** Please tell me who you are.
| Run
| git config --global user.email "you@example.com"
| git config --global user.name "Your Name"
| to set your account's default identity.
| Omit --global to set the identity only in this repository.
| fatal: empty ident name (for <user1@debianpc>) not allowed
ERROR: Task (virtual:native:/..../openstlinux/STM32MP1-Ecosystem/Distribution-Package/layers/meta-st/meta-st-stm32mp/recipes-devtools/openocd/openocd-stm32mp_0.11.0.bb:do_configure) failed with exit code '1'
please help me to fix ...
Kind regards
Bug-report
STM32MP13 Lines
‎2024-03-25 2:03 AM
Hello @developer2 ,
First, I recommend you to go on the very last release of OpenSTLinux if you begin a project (OSTL v5) following the next link: https://wiki.st.com/stm32mpu/wiki/STM32MP1_Distribution_Package
Secondly, the error looks clear in your log, you have not made a git configuration while bitbake needs it for a recipe. Please follow what it tells you in the error logs.
Kind regards,
Erwan
‎2024-03-25 2:03 AM
Hello @developer2 ,
Kind regards,
Erwan
‎2024-03-26 6:46 AM
Thank You ...
