2021-12-13 12:49 AM
Hi, I downloaded the image file required by STM32MP157-EV1 from Yocto, but this error occurred when I used ST32CubeProgrammer. Does anyone know how to solve it?
Error:
Yocto image information:
2021-12-16 06:45 AM
Hi @EYANG.1 ,
Did you succeed to program the Starter Package ?
Could you provide UART log while programming ?
Olivier
2021-12-16 07:19 AM
Hi,@Community member ,
You are right, I did not program the source code, and this is the only message in UART log when I was immigrating images. Is that the cause of problem?
And yesterday, I created a new (.dts )and (.dtsi) in /temp/work-shared/stm32mp1/tfa-source folder. But I still do not know how to update it and create a renewed image by Yocto so that I could run it at STM32 board. Do you have good idea?
Thank you
Edward
2021-12-21 04:51 AM
Hi @EYANG.1 ,
you need check tf-a device tree. The file should contain the settings of the power supply chip ST PMIC STPMIC1. example for STM32MP157A-DK1:
/* USER CODE BEGIN i2c4 */
i2c-scl-rising-time-ns = <185>;
i2c-scl-falling-time-ns = <20>;
clock-frequency = <400000>;
pmic:stpmic@33{
compatible = "st,stpmic1";
reg = <0x33>;
interrupts-extended = <&exti_pwr 55 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
status = "okay";
secure-status = "okay";
regulators{
compatible = "st,stpmic1-regulators";
buck1-supply = <&vin>;
buck2-supply = <&vin>;
buck3-supply = <&vin>;
buck4-supply = <&vin>;
ldo1-supply = <&v3v3>;
ldo2-supply = <&vin>;
ldo3-supply = <&vdd_ddr>;
ldo4-supply = <&vin>;
ldo5-supply = <&vin>;
ldo6-supply = <&v3v3>;
vref_ddr-supply = <&vin>;
boost-supply = <&vin>;
pwr_sw1-supply = <&bst_out>;
pwr_sw2-supply = <&bst_out>;
vddcore:buck1{
regulator-name = "vddcore";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1350000>;
regulator-always-on;
regulator-initial-mode = <0>;
regulator-over-current-protection;
lp-stop{
regulator-on-in-suspend;
regulator-suspend-microvolt = <1200000>;
standby-ddr-sr{
regulator-off-in-suspend;
standby-ddr-off{
vdd_ddr:buck2{
regulator-name = "vdd_ddr";
regulator-min-microvolt = <1350000>;
lp-stop{
regulator-suspend-microvolt = <1350000>;
standby-ddr-sr{
standby-ddr-off{
vdd:buck3{
regulator-name = "vdd";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
st,mask-reset;
lp-stop{
regulator-suspend-microvolt = <3300000>;
standby-ddr-sr{
standby-ddr-off{
v3v3:buck4{
regulator-name = "v3v3";
lp-stop{
standby-ddr-sr{
standby-ddr-off{
v1v8_audio:ldo1{
regulator-name = "v1v8_audio";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
standby-ddr-sr{
standby-ddr-off{
v3v3_hdmi:ldo2{
regulator-name = "v3v3_hdmi";
standby-ddr-sr{
standby-ddr-off{
vtt_ddr:ldo3{
regulator-name = "vtt_ddr";
st,regulator-sink-source;
lp-stop{
standby-ddr-sr{
standby-ddr-off{
vdd_usb:ldo4{
regulator-name = "vdd_usb";
standby-ddr-sr{
standby-ddr-off{
vdda:ldo5{
regulator-name = "vdda";
regulator-min-microvolt = <2900000>;
regulator-max-microvolt = <2900000>;
regulator-boot-on;
standby-ddr-sr{
standby-ddr-off{
v1v2_hdmi:ldo6{
regulator-name = "v1v2_hdmi";
regulator-max-microvolt = <1200000>;
standby-ddr-sr{
standby-ddr-off{
vref_ddr:vref_ddr{
regulator-name = "vref_ddr";
lp-stop{
standby-ddr-sr{
standby-ddr-off{
bst_out:boost{
regulator-name = "bst_out";
vbus_otg:pwr_sw1{
regulator-name = "vbus_otg";
vbus_sw:pwr_sw2{
regulator-name = "vbus_sw";
regulator-active-discharge = <1>;
/* USER CODE END i2c4 */
Apparently, at startup, tfa interacts with this chip, and if it is not configured, then fsbl-boot will not be able to load your image via USB.
I recommend editing the device tree that ST provides
2021-12-22 05:39 AM
Hi @EYANG.1 ,
I notice you load image for EV1 with MP157D
Which mean 800Mhz support.
Can you confirm it's the actual reference of your board ?
Thanks,
Olivier
