2020-12-08 2:51 AM
My goal is to add i2c5 in the dts for userspace access however it is not visible at /sys/bus/i2c/devices. My steps are as follows:
1) bitbake virtual/kernel -c devshell
2) in new shell, modify the arch/arm/boot/dts/stm32mp157a-dk1.dts
3) in new shell, make dtbs or make stm32mp157a-dk1.dtb, and close the new shell
4) in original shell, bitbake virtual/kernel -f -c compile and bitbake virtual/kernel -f -c compile
5) build-openstlinuxweston-stm32mp1/tmp-glibc/deploy/images/stm32mp1/scripts/create_sdcard_from_flashlayout.sh ../flashlayout_st-image-weston/trusted/FlashLayout_sdcard_stm32mp157a-dk1-trusted.tsv and create the .raw for dd to the sdcard
However, with above steps seems the updated dtb file is not populated to the sdcard image. Am I missing some steps?
2020-12-13 4:17 PM
Hi @JLeun.1 ,
Isn't it working by simply doing:
-Modifying your arch/arm/boot/dts/stm32mp157a-dk1.dts file
-bitbake virtual/kernel -C compile
(Your .dtb file is automatically generated in build-openstlinuxweston-stm32mp1/tmp-glibc/deploy/images/stm32mp1/kernel)
-Flashing the .tsv file with build-openstlinuxweston-stm32mp1/tmp-glibc/deploy/images/stm32mp1 directory as binary path
Armand
2020-12-13 4:17 PM
Hi @JLeun.1 ,
Armand
2021-01-20 8:35 AM
Hi @JLeun.1
If a comment answer your question, please close this topic by choosing Select as Best. This will help other users to find that answer faster.
Olivier
