stm32mp1 sgtl5000 codec over i2s
2021-08-09 7:11 AM
Hi All,
i am getting kernel soc sgtl5000.c error
sgtl5000 0-000a: Error reading chip id -6
any idea where am i missing , let me know if you need any further inputs
&i2c1 {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&i2c1__pins_a>;
pinctrl-1 = <&i2c1_sleep_pins_a>;
/*i2c-scl-rising-time-ns = <185>;
i2c-scl-falling-time-ns = <20>;*/
clock-frequency = <400000>;
status = "okay";
/delete-property/dmas;
/delete-property/dma-names;
sgtl5000: codec@0a {
compatible = "fsl,sgtl5000";
reg = <0x0a>;
#sound-dai-cells = <0>;
//clocks = <&clk_ext_audio_codec>;
clocks = <&i2s1>;
clock-names = "MCLK1";
VDDA-supply = <&v3v3>;
VDDIO-supply = <&v3v3>;
sgtl5000_port: port {
#address-cells = <1>;
#size-cells = <0>;
sgtl5000_tx_endpoint: endpoint@0 {
reg = <0>;
remote-endpoint = <&i2s1_tx_endpoint>;
sgtl5000_rx_endpoint: endpoint@1 {
reg = <1>;
remote-endpoint = <&i2s1_rx_endpoint>;
&i2s1 {
#clock-cells = <0>;
clocks = <&rcc SPI1>, <&rcc SPI1_K>, <&rcc PLL3_Q>, <&rcc PLL3_R>;
clock-names = "pclk", "i2sclk", "x8k", "x11k";
pinctrl-names = "default";
pinctrl-0 = <&i2s1_pins_mx &i2sa_pins_z>;
status = "okay";
i2s1_tx_port: port@0 {
i2s1_tx_endpoint: endpoint {
remote-endpoint = <&sgtl5000_tx_endpoint>;
format = "i2s";
mclk-fs = <256>;
i2s1_rx_port: port@1 {
i2s1_rx_endpoint: endpoint {
remote-endpoint = <&sgtl5000_rx_endpoint>;
format = "i2s";
mclk-fs = <256>;
sound{
compatible = "audio-graph-card";
routing =
"MIC_IN", "Capture",
"Capture", "Mic Bias",
"Playback", "HP_OUT";
dais = <&i2s1_tx_port &i2s1_rx_port>;
status = "okay";
I2S
STM32MP15 Lines
2021-09-01 2:14 AM
Hi @Ara.1 ,
You have posted several questions related to same problem.
We will gather all support under post : https://community.st.com/s/question/0D53W000010RjZfSAK/sgtl5000-codec-dsi-i2c
Olivier
2021-09-01 3:33 AM
Yes i had done this as i was not getting any response on this, query, i assumed to draft in detailed way so created a new quest,
