qt aplication problem: Failed to create wl_display
  • August 19, 2024
  • 1 reply
  • 10953 views
Hello @Erwan SZYMANSKI
I hope your week started well.
I think the script didn’t work because I couldn't adjust the paths correctly. Could you please assist me in finding the correct paths and adjusting my script accordingly?
# !/bin/sh
export QSG_INFO=1
export QML2_IMPORT_PATH=~/imports/
export PATH=/usr/local/qt5-install/bin/:/usr/local/apitrace/bin:$PATH
export QT_QPA_PLATFORM=wayland
#Execute the Qt program
export XDG_RUNTIME_SESSION=wayland; export XDG_RUNTIME_DIR=/run/user/1000; export WAYLAND_DISPLAY=wayland-1; cd /usr/bin && ./automotive
nesnes@nesnes-ABRA-A5-V19-2:/usr/local$ tree -L 2
├── bin
├── etc
├── games
├── include
├── lib
│ └── python3.10
├── man -> share/man
├── sbin
├── share
│ ├── ca-certificates
│ ├── fonts
│ ├── man
│ ├── sgml
│ ├── texmf
│ └── xml
└── src
1 reply
nesnesAuthor
@Erwan SZYMANSKI   I think it is on x11 as a default so I want to try that how can I do the adjustments for that
root@stm32mp15-disco:~# automotive
qt.qpa.plugin: Could not find the Qt platform plugin "xcb" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland.
Aborted (core dumped)
root@stm32mp15-disco:~# run_automotive
Failed to create wl_display (No such file or directory)
qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
I run this command
root@stm32mp15-disco:~# export QT_DEBUG_PLUGINS=1
QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/plugins/platforms" ...
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/plugins/platforms/libqeglfs.so"
Found metadata in lib /usr/lib/plugins/platforms/libqeglfs.so, metadata=
 "IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
 "MetaData": {
 "Keys": [
 "eglfs"
 "archreq": 0,
 "className": "QEglFSIntegrationPlugin",
 "debug": false,
 "version": 331520
Got keys from plugin meta data ("eglfs")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/plugins/platforms/libqminimal.so"
Found metadata in lib /usr/lib/plugins/platforms/libqminimal.so, metadata=
 "MetaData": {
 "Keys": [
 "minimal"
 "archreq": 0,
 "className": "QMinimalIntegrationPlugin",
 "debug": false,
 "version": 331520
Got keys from plugin meta data ("minimal")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/plugins/platforms/libqminimalegl.so"
Found metadata in lib /usr/lib/plugins/platforms/libqminimalegl.so, metadata=
 "MetaData": {
 "Keys": [
 "minimalegl"
 "archreq": 0,
 "className": "QMinimalEglIntegrationPlugin",
 "debug": false,
 "version": 331520
Got keys from plugin meta data ("minimalegl")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/plugins/platforms/libqoffscreen.so"
Found metadata in lib /usr/lib/plugins/platforms/libqoffscreen.so, metadata=
 "MetaData": {
 "Keys": [
 "offscreen"
 "archreq": 0,
 "className": "QOffscreenIntegrationPlugin",
 "debug": false,
 "version": 331520
Got keys from plugin meta data ("offscreen")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/plugins/platforms/libqvnc.so"
Found metadata in lib /usr/lib/plugins/platforms/libqvnc.so, metadata=
 "MetaData": {
 "Keys": [
 "vnc"
 "archreq": 0,
 "className": "QVncIntegrationPlugin",
 "debug": false,
 "version": 331520
Got keys from plugin meta data ("vnc")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/plugins/platforms/libqwayland-egl.so"
Found metadata in lib /usr/lib/plugins/platforms/libqwayland-egl.so, metadata=
 "MetaData": {
 "Keys": [
 "wayland-egl"
 "archreq": 0,
 "className": "QWaylandEglPlatformIntegrationPlugin",
 "debug": false,
 "version": 331520
Got keys from plugin meta data ("wayland-egl")
QFactoryLoader::QFactoryLoader() looking at "/usr/lib/plugins/platforms/libqwayland-generic.so"
Found metadata in lib /usr/lib/plugins/platforms/libqwayland-generic.so, metadata=
 "MetaData": {
 "Keys": [
 "wayland"
 "archreq": 0,
 "className": "QWaylandIntegrationPlugin",
 "debug": false,
 "version": 331520
Got keys from plugin meta data ("wayland")
QFactoryLoader::QFactoryLoader() checking directory path "/usr/bin/platforms" ...
loaded library "/usr/lib/plugins/platforms/libqwayland-generic.so"
nesnesAuthor
@Erwan SZYMANSKI  I couldn't fix the issue can you help me solve it
root@stm32mp15-disco:~# ls /usr/lib/qml/QtQuick/Layouts/
libqquicklayoutsplugin.so plugins.qmltypes qmldir
root@stm32mp15-disco:~# chmod 755 /usr/lib/qml/QtQuick/Layouts/libqtquicklayoutsplugin.so
chmod: cannot access '/usr/lib/qml/QtQuick/Layouts/libqtquicklayoutsplugin.so': No such file or directory
root@stm32mp15-disco:~# chmod 755 /usr/lib/qml/QtQuick/Layouts/libqquicklayoutsplugin.so
root@stm32mp15-disco:~# export QT_QPA_PLATFORM=offscreen
QStandardPaths: runtime directory '/run/user/1000' is not owned by UID 0, but a directory permissions 0700 owned by UID 1000 GID 1000
QQmlApplicationEngine failed to load component
qrc:/qml/automotive.qml:5:1: plugin cannot be loaded for module "QtQuick.Layouts": Cannot protect module QtQuick.Layouts 2 as it was never registered
PPAGE.13
Hello @nesnes
we recently published a meta layer for Qt5 installation, this is available here:
https://github.com/STMicroelectronics/meta-st-x-linux-qt
And doc at :
https://wiki.st.com/stm32mpu/wiki/X-LINUX-QT_Expansion_Package
Hope it can help you to have a correct QtQuick.Layout package installation.
BR,
Philippe.
