2024-03-12 4:40 AM - edited 2024-03-13 8:46 PM
i am using ubuntu 22.04 ltsThe above mentioned photo is what was the output when i follow Readfile. How to do.txt;
i cannot able to figure out what was the issue.And because of this issue i am getting this issue isn't it? (below attached)
Now this error evolved like this.
2024-03-18 6:59 AM
Did you source the SDK before compiling?
Grégory
2024-03-18 6:59 AM
Grégory
2024-03-19 12:13 AM - edited 2024-03-19 12:19 AM
yes,but first i did it wrongly. now i sourced the file and build kernel on same terminal(only changed directory based on your location). now issue shorted. thank you
