How to define GPIOs as simple input/output in STM32CubeMX?
‎2021-05-25 1:21 AM
I'm trying to define some GPIOs as simple input/output for STM32MP157. I'm using the STM32CubeMX tool, but I can't find where to assign the GPIOs to A7 or M4. In the pinout view, I correctly set them as input/output but when I generate the code, I don't find their definition, nor in the device tree .dts, neither in the m4 code (only clock enable is present).
GPIO-EXTI
STM32CubeMX
STM32MP15 Lines
‎2021-05-25 1:34 AM
For M4, after selecting GPIO input or output, you also have to right click on the pin and assign 'pin reservation' to 'Cortex-M4'.
M4 code will then be generated correctly.
For A7, there is no automated generation of device tree in CubeMx, you should add it manually.
For A7/Linux, see:
https://wiki.st.com/stm32mpu/wiki/Overview_of_GPIO_pins
https://wiki.st.com/stm32mpu/wiki/GPIO_device_tree_configuration
https://wiki.st.com/stm32mpu/wiki/How_to_control_a_GPIO_in_userspace
Regards.
‎2021-05-25 1:34 AM
For A7/Linux, see:
Regards.
‎2021-05-25 2:16 AM
@PatrickF​ Thank you very much!
‎2021-05-25 2:20 AM
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
