how to install python submodule on stm32mpu
‎2023-12-17 6:37 PM - edited ‎2023-12-17 6:45 PM
Hi
I used pip3 install python submodule.
The submodule inclued xxx.c files.
The install processing be use 'arm-ostl-linux-gnueabi-gcc' compiler tool, The processing be fail.
I can't find gcc-arm-aarch32-arm-none-linux-gnueabi tool for The STM32MPU157-DK2.
I find out tools are 'gcc-arm-aarch64-arm-none-linux-gnueabi', But it can't use on the STM32MPU157-DK2.
I use STM32-SDK provider comliler tools, it is don't working too.
The other question,
The other way, How to install python submodule in the linux kernel image?
STM32MP15 Lines
‎2023-12-17 11:53 PM
Hello @NashHsu
The image installed on STM32MP boards doesn't contain any toolchain nor *-dev or *-src packages hence the errors you may face when trying to install python modules which need to be built on the board.
To add the python module which requires a compilation, you need to create the corresponding recipes into your Yocto environment.
To add a new recipe, please follow this wiki page: https://wiki.st.com/stm32mpu/wiki/How_to_add_a_customer_application
To build the recipe for your Python module, you can use the pipoe utility (https://pypi.org/project/pipoe/) from your host PC:
$> pip3 install pipoe $> pipoe -p <your python module> --python python3
And then just copy the generated .bb file to your layer.
For your next question, I don't have any idea. Please open a new thread for this specific item so the community will help you.
Best regards,
--JM
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
‎2023-12-19 9:55 PM
Okay.
Can I install the PYTHON subpackage on an operating system as an image?
‎2023-12-20 12:02 AM
Hi @NashHsu
Yes, you can install a python sub-package into your image. Once you have written the recipe for your python module, please refer to this wiki page to add it to your image: https://wiki.st.com/stm32mpu/wiki/How_to_add_a_customer_application#Quickly_add_the_recipe_to_an_image
Best regards,
--JM
