Boot failure of image built using copied distro, machine, image recipe from ST's meta.
2023-11-14 2:07 AM
I have a custom board based on stm32mp157f-ev1 and stm32mp157f-dk2 board.
In my custom layer:
- meta-st/meta-st-openstlinux/conf/distro/* copied and a new distro created based openstlinux-weston.conf
- meta-st/meta-st-stm32mp/conf/machine/* copied and a new machine created based stm32mp15-eval.conf
- a new image recipe created based meta-st/meta-st-openstlinux/recipes-st/images/st-image-weston.bb
linux-stm32mp, u-boot-stm32mp, tf-a-stm32mp DTS files tuned using openembedded devtool.
Image built using:
$ DISTRO=mydistro MACHINE=mymachine META_LAYER_ROOT=layers/mylayer layers/meta-st/scripts/envsetup.sh
$ bitbake-layers add-layer ../layers/mylayer
$ bitbake myimage
Flashed on sdcard and try to boot, but stucked after RAMDISK error message:
[ 2.714949] hub 2-0:1.0: USB hub found
[ 2.717446] hub 2-0:1.0: 2 ports detected
[ 2.726168] RAMDISK: Couldn't find valid RAM disk image starting at 0.
[ 2.731801] Waiting for root device PARTUUID=491f6117-415d-4f53-88c9-6e0de54deac6...
[ 3.007728] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 3.210055] hub 2-1:1.0: USB hub found
[ 3.212707] hub 2-1:1.0: 4 ports detected
[ 3.537716] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
Any tunning required after copying ST meta ?
Best Regards,
YoungSuk Kim
STM32MP15 Lines
2023-11-16 1:53 AM
Hello @bandifly ,
I just would like to target the right problem location. Can you please tell me if updating components in a standalone way (with Developer Package and SDK) give you the same bad status ?
We need to identify if you are facing a Yocto issue or a SW component modification issue.
Kind regards,
Erwan
