on 2021-11-16 01:48 AM
Micro USB Cable used to power and debug.
Download the X-CUBE-AWS package. You may need to create an account on st.com for the same.
Open STM32CubeIDE. Click on File->Open Projects from File System. Import the following projects into the workspace from the following paths:
C:\STM32CubeExpansion_Cloud_AWS_V2.0.0\Projects\B-L4S5I-IOT01A\Applications\BootLoader_STSAFE\2_Images_SECoreBin\STM32CubeIDE\B-L4S5I-IOT01_2_Images_SECoreBin
C:\STM32CubeExpansion_Cloud_AWS_V2.0.0\Projects\B-L4S5I-IOT01A\Applications\BootLoader_STSAFE\2_Images_SBSFU\STM32CubeIDE
C:\STM32CubeExpansion_Cloud_AWS_V2.0.0\Projects\B-L4S5I-IOT01A\Applications\BootLoader_STSAFE\STSAFE_Provisioning
C:\STM32CubeExpansion_Cloud_AWS_V2.0.0\Projects\B-L4S5I-IOT01A\Applications\Cloud\aws_demos\STM32CubeIDE
Click on Finish to import the STM32CubeIDE project as shown below:
This is what the projects imported into the workspace looks like:
Build B-L4S5I-IOT01_2_Images_SECoreBin, B-L4S5I-IOT01_2_Images_SBSFU, B-L4S5I-IOT01_STSAFE_Provisioning and B-L4S5I-IOT01_aws_demos projects by clicking the following icon:
Make sure that you build in the order that is mentioned otherwise build errors will be generated.
Go to the project explorer and drag and drop the binary to the board(eg: DIS_L4S5VI) from the following path (C:\STM32CubeExpansion_Cloud_AWS_V2.0.0\Projects\B-L4S5I-IOT01A\Applications\Cloud\aws_demos\STM32CubeIDE\Debug) as shown below:
Go back to the IDE and click on the drop-down arrow next to the bug button and click on Debug configurations.
7.The following debug window will open:
Click on Startup.
8.Double click on true under download
The following tab will pop up:
9.Uncheck download as shown above and click OK. Under Name, give it a different name for example, B-L4S5I-IOT01_aws_demos Debugnodownload and Close.
10.Place a breakpoint at a line of your choice in main() by double clicking on the line. I have placed the breakpoint here in line 213:
11. In the dropdown next to the bug, click on B-L4S5I-IOT01_aws_demos Debugnodownload. Make sure that the board is connected to your laptop.
12. Following prompt will appear. Click on Switch.
13. Once launched, the debugger will stop at the first line of main().
14. Click on resume. The debugger will stop at the breakpoint.
15. You can Step over the function. Stepping over will go into the next line of execution of the code as shown below.
You can also step into the function by clicking the following icon:
It will take you into the function. Additionally, you can also press and hold control (CRTL on the keyboard) and click on the function to be taken into the function.
If you wish to relaunch the debugger, click on Terminate and Relaunch as shown below:
STM32CubeIDE: STM32CubeIDE - Integrated Development Environment for STM32 - STMicroelectronics
STM32L4S5 user and reference manual: www.st.com/en/evaluation-tools/b-l4s5i-iot01a.html#documentation
The images aren't loading for some of this page.
Hi @Jenni, thanks for your feedback.
Unfortunately we are not able to recover these images, so we will provide fresh ones ASAP.
Best regards,
Laurids
