What antenna filter can I use with STM32WB55 using BLE
‎2021-04-16 12:00 AM
I use a STM32WB55RGV7 microcontroller. Doing the hardware layout I'm confused about the antenna filter:
- I can't get the band pass filter LFB182G45CGFD436 in small quantities, which is used in the P-Nucleo-WB55
- the low pass filter LFL212G45TC1A007, wich is used in AN5165, is end of life in about one year
- AN5165 uses also another low pass filter MLPF-WB55-01E3, which makes a part of the other componets unnessesary
Could you give me a suggestion which of these filters I can use in my design reasonably future-proof?
Thanks in advance.
Holger
STM32WB series
‎2021-04-16 12:38 AM
Welcome, @HLenk.1​, at the community!
the MLPF-WB55-01E3 is definitely the recommended filter for all STM32WB55. A product longevity of at least 10 years is already guaranteed for the WB55 family (rolling commitment), so that it is very likely that a similar product lifespan can be assumed for the filter.
Good luck!
/Peter
Good luck!
/Peter
‎2021-04-16 3:39 AM
Thanks. Your answer is very helpfull.
