STM32WBA bootloader signing and verification
‎2025-02-21 3:28 PM - last edited on ‎2025-02-24 1:50 AM by STTwo-32
Hi community, I understand that users can encrypt and sign firmware using STM32CubeProgrammer. My question is about the first stage bootloader provided by ST. From my limited reading, it seemed that this 1st stage ST bootloader is only encrypted but not signed. Is my understanding correct? If not, please can someone point to me the document describing how does ST do the 1st stage bootloader signing and where the verification key is programmed on the MCUs?
Thanks, and best regards
James
- Labels:
Bootloader
STM32WBA series
‎2025-03-21 7:32 AM
Hello @JamesNi
Regarding the ST supplied bootloader in the system flash, it is not encrypted and not meant for sophisticated customer and field application use. The only purpose of that bootloader is to load code into the device.
The actual application is supposed to reside in the user flash and that's done through the OEMiROT supplied in the STM32CubeWBA package. The OEMiROT is encrypted and signed and supports authentication and verification.
Best Regards.
STTwo-32
‎2025-02-24 12:54 PM - edited ‎2025-02-24 1:09 PM
Hi JamesNi
This post has been escalated to the ST Online Support Team for additional assistance. Should anyone else have a similar question about documentation, please submit your request directly to the ST Online Support Team at https://my.st.com/ols
Joe
STMicro Support
‎2025-03-21 7:32 AM
Hello @JamesNi
Best Regards.
STTwo-32
