2021-01-12 6:38 PM
When i connect the STM32WB55 with PC via USB cable on ST-Link Port,
This window is prompted on my screen with Fail.TXT file showing message as shown in PIC
what can be the reason and issue?
I have connected WB first time to my PC
2021-01-21 3:07 PM
Well yeah above problem was coming because i have not connected the connectors on Jumper 3, so My MCU is not getting Powered from power supply thus it is getting error like this
2021-01-21 11:33 AM
It may be easier for you to use the CubeProgrammer tool you can download on the www.st.com.
2021-01-21 3:07 PM
