Spurious BLE disconnection
‎2023-07-12 1:57 AM
I am using two device that are connected one to another with BLE.
The first device is a server.
The second is a routeur.
I detect some spurious disconnection between both device after some random time.
The disconnection error I get is : HCI_CONNECTION_TIMEOUT_ERR_CODE
Do you have any idea what could be the cause and how I could fix it?
The server device writes sometimes into the flash, but it should write on the flash only during specific moments
Thank you in advance
- Labels:
STM32WB series
‎2023-07-20 9:44 AM
Did you follow the algorithm to write/erase data in the flash memory (see figure 10) describes in AN5289? In STM32CubeWB package, BLE_RfWithFlash example demonstrate the capability to erase/write the flash while a Point-to-Point communication using BLE component is active using the flash drive which follow the algorithm.
Best Regards
‎2023-07-20 9:44 AM
Best Regards
‎2023-07-24 3:29 AM
Thank you for your reply.
I indeed implemented the algorithm to write/erase data in the flash memory as described in AN5289 and it seemed to solve my problem.
Thank you very much !
