Single bonded device in STM32WB
2024-02-29 12:06 PM
I am programming an STM32WB5MMG module. Is it possible to limit the number of bounded devices to one?
One process could be to bound to one device and when I want to bound another, delete all previously bounded devices. However, I would like to only delete the stored device once a new one has been successfully bounded. Is this possible?
My idea is to make use of the whitelist to only allow connections from the bounded device. The system has a button from which to deactivate the whitelist and allow a different device to be bounded (but as I said, I would like to only delete the old device if a new one is successfully bounded).
Best regards and thank you for your time.
BLE
STM32WB series
2024-04-15 9:07 AM
Hello @thealbertdev
I think your implementation can do the job. But you should first understand how works the bounding procedure.
Best Regards.
STTwo-32
