2023-11-30 02:42 AM
I am downloading the firmware \STM32Cube_FW_WB_V1.17.0\Projects\STM32WB_Copro_Wireless_Binaries\STM32WB1x\stm32wb1x_BLE_Stack_full_fw.bin to the STM32WB15CC using STM32CubeProgrammer v2.14.0, with USB cable.
At the end, I have :
11:21:53:481 : Error: failed to download Segment[0]
11:21:53:481 : Error: failed to download the File
If I try to download stm32wb1x_Safeboot_fw.bin, there is no error.
Where is the problem ? All products are from STMicroelectronics...
Thank you for help.
FWX.
2023-11-30 06:03 AM
Hi Remy,
Thank you for the link and your useful explanations.
Best regards,
FWX.
2023-11-30 04:24 AM
In this wiki page, all steps to update the wireless stack are described, can you check if your sequence it's the same or not? In addition, according to the release note the install address for BLE Full Stack v1.17.0 on WB15 is 0x08021000.
Best Regards
2023-11-30 06:03 AM
Hi Remy,
Best regards,
FWX.
