NUCLEO-WL55JC1 bricked after 2nd flash?
I recently bought a NUCLEO-WL55JC1 to try. I ran a very simple Mbed OS6 program (with serial output and an LED flashing), I had previously been running on an F411, which ran fine. I then changed a single variable (ms for LED flashing), and when I attempted to redeploy the modified code, it won't run.
I have tried vanilla "blinky" code, and the "mbed-os-example-lorawan", but nothing runs. The STLINK flasher LED flickers green/red, as expected, to indicate a programme flash, but no activity thereafter. I have tried upgrading the firmware to V3.J9.M3, but still no luck. Debugging also will not connect and it "actively refused".
Any ideas why this might be happening?
Thanks in advance.
