Not able to get BLE working on STM32WB55CGU6
‎2025-03-17 1:43 AM
I'm trying to get BLE working on my custom STM32WB55CGU6 board. I was following this tutorial since it matches well with my setup: STM32 Bluetooth Firmware Tutorial (Bring-Up) - Phil's Lab #129
However I am not able to see my board using nRF Connect app. Code does not seem to end in any error and keeps looping this part:
while (1)
/* USER CODE END WHILE */
MX_APPE_Process();
/* USER CODE BEGIN 3 */
I have flashed the FUS and BLE_Stack_full_fw using STM32CubeProgrammer:
I'm new with STM32CubeIDE tool and would appreciate any help in this matter :smiling_face_with_smiling_eyes:
Here is my full program with schematic of the board: https://github.com/nikorainto/STM32WB55CGU6_BLE_TEST
- Labels:
BLE
STM32WB series
‎2025-03-17 5:24 AM
Thank you, currently the MCU is running FUS.
STM32WB Firmware Upgrade Service - stm32mcu
Please connect the board to STM32CubeProgrammer, click on "Start Wireless Stack" button and flash the application again. It should fix the issue.
Best regards,
FK
‎2025-03-17 2:25 AM
can you please place a breakpoint in APPE_SysUserEvtRx function to see the event code? (app_entry.c)
You can start debugging by clicking on the bug button.
Best regards,
FK
‎2025-03-17 3:10 AM
Thank you for reaching out :smiling_face_with_smiling_eyes: I took a screenshot of the values it shows
‎2025-03-17 4:15 AM
The event code seems okay. Can you please step further?
In APPE_SysEvtReadyProcessing function, the code should jump at WIRELESS_FW_RUNNING.
APP_BLE_Init() function must be called to start advertising.
Best regards,
FK
‎2025-03-17 5:06 AM - edited ‎2025-03-17 5:07 AM
It seems not to enter the "wireless firmware running" block but instead this
else if (p_sys_ready_event->sysevt_ready_rsp == FUS_FW_RUNNING)
* The FUS firmware is running on the CPU2
* In the scope of this application, there should be no case when we get here
APP_DBG_MSG(">>== SHCI_SUB_EVT_CODE_READY - FUS_FW_RUNNING \n\r");
/* The packet shall not be released as this is not supported by the FUS */
((tSHCI_UserEvtRxParam*)pPayload)->status = SHCI_TL_UserEventFlow_Disable;
Red arrow points that the second breakpoint is not reached
‎2025-03-17 5:24 AM
Best regards,
FK
‎2025-03-17 5:49 AM
Thank you a lot! Somehow I have missed this step but it seemed to fix and now I'm able to continue!
