2019-07-23 12:32 AM
hello,
Please be kind to me as I am new to this. I have a B-L072Z board.Use the End_Node program to communicate with the lora gateway, I found that the data transmission interval of the terminal is 10 seconds. I can reduce the time to 7 seconds by changing the value of "APP_TX_DUTYCYCLE". But I want to set the data transmission interval to less than 1 second,is that ok ? If so, how can I modify the End_Node program? Thank you very much!
