Looking to built my own lorawan network server.
Yash_want
Hello everyone,
I'm looking to built my own lorawan network. Currently I'm using loriot server. As we need to pay these server. I'm looking to build my own.
Looking for the help/guidance on do we need any type of access or permission from these gateway hardware manufactures to configure there gateway on particular server?
As of my search connection to a lorawan server relies on software embedded by the gateway hardware manufacturer.
If this is the case can anyone help me with how can i proceed about above case.
Thank you.
4 REPLIES 4
Andrew Neil
This really doesn't have anything to do with STM32 Microcontrollers.
For Network Server you wouldn't be looking at microcontrollers at all - that's a datacentre type of application!
Have you looked at The Things Network (TTN) - they have a free offering, and there are plenty of Gateways compatible with it...
https://www.thethingsnetwork.org/
Yash_want
Andrew Neil
"Run your private The Things Stack network server on a Raspberry Pi with balena"
https://blog.balena.io/run-your-private-the-things-stack-network-server-on-a-raspberry-pi-with-balena/
In India: https://www.thethingsnetwork.org/country/india/
