Is it multi-regional application possible?
OSole.1
Hi, everyone.
Is it possible to build an application that supports all regional standards? AS923-1 / AS923-2 / AS923-3 together are of particular interest (depending on the setting, which is changed via the UART, for example).
Uwe Bonnes
Chief
There is no fundamental limit what you can implement, so yes, a multi-regional application is possible. But be prepared that a lot has to be done by you yourself
OSole.1
It's a pity. But thanks for the answer anyway.
