I am making a LoRa application-based project using STM32WLE5. The confusing part for me is which power source I should select "HIGH POWER' or "LOW POWER' for RF. The band is EU868 (South Africa).
Soham Mistry.
Typically there are two paths, do you need the PA (Power Amplifier), or the broader range of power settings with both paths?​
Soham Mistry.
Yes, we need the Power Amplifier, and can you please elaborate on the second option?
