How to enable debug messages in BLE_HeartRateFreeRTOS demo
asala.19
Can any one guide me how can i enable debug messages in BLE_HeartRateFreeRTOS demo.
i have enable below macro but doesn't get any success
#define CFG_DEBUGGER_SUPPORTED  1
#define CFG_DEBUG_BLE_TRACE   1
#define CFG_DEBUG_APP_TRACE   1
#define CFG_DEBUG_TRACE_LIGHT   1
Please help me what i am missing i need debug print come from
APP_DBG_MSG and BLE_DBG_HRS_MSG.
Thanks,
Arjun
2 REPLIES 2
Remi QUINTIN
Could you please try with the new CubeWB FW package V1.8 avaible on our web site?
Setting the #define to 1 should be enough.
Hugues DE CARVALHO
Hi Arjun,
I advise you change the CFG_*** in CubeMX under Middleware -> STM32_WPAN.
You will notice that you can only enable CFG_DEBUGGER_SUPPORTED if Sys Debug is enabled.
If you only want to display the logs, enabling:
should work.
I however observed that logs aren't be outputed when compiling with CubeIDE. The same project would output logs when compiled with IAR.
I am investigating this issue, I will get back to you if I find a fix.
Best Regards,
Hugues
