Hi,I'm using the WB55RG-NUCLEO board,I upload the FUS and stack(1.16.4), I upload the firmware BLE TRANSPARENT MODE in cube IDE, In debug mode but when i step over HAL_GPIO_Init(GPIOA, &gpio_config) in MX_APPE_Init();,it says target is not responding
Sheik_Abdullah_P
Remy ISSALYS
By default the support of debugger is not supported in BLE_TransparentMode see the following define in app_conf.h file:
#define CFG_DEBUGGER_SUPPORTED    0
So, you have to set this define to 1 if you want to debug.
Best Regards
Announcement
